I have gotten the task of finding an appropriate connector for our application, but given so much information there is on connectors, I don't even know which information is relevant.
So this is the task;
I have a cable that has a strand of 10 smaller insulated wires inside. I must find an appropriate connector that will guarantee IP 67 protection.
I measured some of the dimensions of my cable and they are;
Cable outer diameter = 6.5 mm
Wire insulation outer diameter = 1.1 mm
Wire copper cross-section = 0.205 mm²
My question is where do I search for the connectors? Is it at the sellers like Mouser and Farnell, or should I try looking straight to the manufacturers? How do you find the right connector in the vast sea of all the possibilities?
Thank you all.
Additional information:
The connector is going to be used in automotive application. The wires will transmit mostly digital signals for communication and a pair for supply power of 12V no more than 1A. It should be wire-to-wire attachment.
