For my product I'm designing an enclosure and I thought that I could use a PCB to make the cover. I can place copper traces as touch buttons, and remove solder mask and copper to make semi-transparent holes for LEDs. However, I've never seen a commercial product have an exposed PCB, except some products directly sold to makers (e.g. https://teenage.engineering/products/po).
Is there a reason for this?
The only reasons I can come up with are:
  • cost for big quantities vs. plastic (not my case right now)
  • less "refined" aesthetics vs. plastic
Are there any other reasons? Possible safety risks? Certifications needed? Note that my product has 380V AC inside, but the front PCB is galvanically isolated.
MGG
In Europe, if your case has conductive parts, it needs to be grounded. So, unless you're only using a single-sided PCB with no metal going through the PCB substrate, that will require a three-pin connector, which is a big no-go in a lot of situations. In the other situations, using a bit of shaped sheet metal as enclosure is probably a lot easier (not necessarily cheaper material-wise, since you'd need a tool made to build the exact shape of metal, but easier to mount things in, easier to handle, store, test). I am not a lawyer or product design expert – but probably there are more reasons than these.
Also, 380V AC sounds a lot like you want a stable enclosure. PCBs aren't meant for this kind of applications – they are relatively brittle / not shock resistant.
In all cases, a letal-voltage enclosure will be required to be "reasonably foolproof". Dropping the thing shouldn't expose the internals. Building that from PCBs sounds like a lot of structural elements (standoffs, guides/shafts/profiles…) need to be added to make a PCB enclosure reliable. That will have inhibitive complexity.
Also, and this will vary very much with legislation, exposed edges of fiber glass material themselves might be prohibited. You don't want to shave of fibers. Again, this can be solved with using non-PCB edges/guides and whatnot, but at that point, the PCB becomes more of a problem than a solution.
Marcus Müller
  • 88,280
  • 131
  • 237
  • You could probably design it with an exposed PCB surface, but with a proper structural cover under it. Also some PCB are made with lead, so you probably want to avoid that. – hekete Jun 04 '19 at 13:41
  • @hekete these lead-containing PCBs would most probably be already problematic inside the device, under the RoHS directive. – Marcus Müller Jun 04 '19 at 13:43
  • Thanks for the insight. To clarify: PCB will run on 5V and be galvanically isolated from the HV circuitry, there are no exposed copper surfaces, there is copper under solder mask but it's grounded. Enclosure is strong and solidly fixed to a wall, the PCB is mostly cosmetic and is not subject to strong forces. The PCB will have its edged exposed only during installation, as after that its border is hidden behind a snap-on plastic frame. – MGG Jun 04 '19 at 14:07
  • Again, not a product design expert. But if you have something that is screwed to a wall, has a snap-on plastic frame: why expose the PCB at all? Also, as far as I can see, internal galvanic isolation doesn't matter. Metal enclosure parts == earthing requirement. – Marcus Müller Jun 04 '19 at 14:19
  • It's for design customization and cost reasons. Plastic required an additional mold, and I'd still have to fabricate the PCB of a similar size for LEDs, touchpad and other stuff anyways. – MGG Jun 04 '19 at 14:25
  • that argument doesn't work: where you can put a flat PCB, you could also put a flat piece of plastic, which doesn't need to be molded. And typically, if you're cost-constrained, you'd reduce the size of the touchpad PCB as far as possible, just have wired LEDs that you attach to the small PCB with cheap cables and so on. Again, all discussions are moot: if there's 380 V inside, using a brittle surface is simply not an option. Full stop. – Marcus Müller Jun 04 '19 at 14:28
  • If it's 'mostly' cosmetic, make it entirely cosmetic. Just have a proper structural plate behind it. No molding needed, its just a flat plate. It doesn't really matter what the intended forces to be applied to it are, it's the unintended forces you have to worry about. The PCB snaps really easily, now someone is touching 380V live wire. – hekete Jun 05 '19 at 05:14
  • Well, having a laser cut plastic sheet was the original idea before considering the PCB, but it turned out to be more expensive than the PCB itself... And for what I tested, it's also more fragile, and it also has to be fire resistant (V0). Maybe I'm missing something obvious, is there some kind of plastic that it's cheap, strong, fire resistant and cheap to cut? – MGG Jun 06 '19 at 08:54
