I have two actuators each of them with the following characteristics: 16 inch, 12v, load 750 N, travel speed 10mm / s, duty cycle 25%
BUT Current Draw is not specified, and I have no access to the datasheet.
I think in some scenarios:
-> let's say each actuator is of 2.5 Amps then I need a power supply of 5A Amperes.
-> let's say each actuator is of 4 Amps then I need a power supply of 8A
-> let's say each actuator if 6.5A Then I need a power supply of 13A
The thing is I dont know the Max Current Draw of each actuator, then my doubt is:
  • What happens if the current of my power supply is too much bigger than the current I need for the lineal actuators. Let's say the lineal actuators need for both 5A and my power supply is of 10 A.
  • What happens if the current of my power supply is too much lower than the current I need for the lineal actuators. Let's say the lineal actuators need for both 13A and my power supply is of 10 A.
Then I don't know what happens in that scenarios, and also in muy situation Which power supply would be the more convenient to buy?
Thanks in Advance.
Best Regards
punk code
  • https://electronics.stackexchange.com/questions/34745/choosing-power-supply-how-to-get-the-voltage-and-current-ratings – Bruce Abbott May 26 '19 at 00:15
  • Thanks, I see the selected answer but it does not answered this scenario...... What happens if the current of my power supply is too much lower than the current I need for the lineal actuators. Let's say the lineal actuators need for both 13A and my power supply is of 10 A. – punk code May 26 '19 at 02:59
  • I will check the other answers.. – punk code May 26 '19 at 03:01
  • If you cannot find Motor resistance from site or supplier, walk away or gamble and buy it – Tony Stewart EE75 May 26 '19 at 11:20
0 Answers0
