I inserted a two-pin header (P1) into this circuit using EasyEDA. Does the square outline mean that is the positive pin, or is there another meaning?
Asked
Active
Viewed 146 times
1Square pin is pin one, this has been asked on here before, so Elliot's link should show you what you need! – Hearth May 07 '19 at 22:53
Ah perfect, Elliot's link explains it all, so I'll close this one. – Mark Harrison May 07 '19 at 22:55
The square pin usually means it's pin 1. The polarity is up to you. Look at the 1x3 or other headers with more pins in the library, this will make more sense.
Voltage Spike
- 75,799
- 36
- 80
- 208
