I have designed custom-made PCB with STM32L071C8 MCU. I'm using OpenOCD 'master' branch and SWD interface via FT2232H to debug the MCU.
I successfully did some RAM reading and Flash writing, erasing on the MCU via the OpenOCD so the OpenOCD ->FT2232H-> SWD on MCU works.
But, I have a weird problem with writing to Flash more than 192 bytes or in other words 128 bytes (page) + 64 (half page). the OpenOCD prints an error message about failing to write the data to the desired flash address
error writing to flash at address 0x08000000 at offset 0x00000000
I have executed OpenOCD with debug prints and came up with these logs.
Log of successfully writing 100 bytes to flash.
Log of failure to write 192 bytes to flash - the problem described above.
as you can see in the logs I'm using 'fillb' OpenOCD command to write bytes to flash.
Before each 'fillb' command I take care to erase the desired flash page. I didn't mention the erasing in log.
Have you any advice about how can I investigate this problem? or maybe any solution?
