I have following scenario
I[n] = nth Data Input, where n=1 to N
W = bit width of I[n]
A[k] = output of a signed adder, where k = 1 to N-1
I want to use my signed adders in following way:
A[1] = I[1] + I[2]
A[2] = A[1] + I[3]
A[3] = A[2] + I[4]
A[N-1] = A[N-2]+I[N]
As we are doing signed addition, bit length of output of each signed adder should be 1+(bit length of data input to the adder)
Thus the bit widths of adder output A[n] should be follows
A[1] W+1
A[2] W+2
A[3] W+3
A[N-1] W+N-1
My question is if N is a generic parameter, is it possible to declare in VHDL an array of N std_logic_vector's with bit-widths as W+1, W+2, W+3,... W+N-1 ?
The simple workaround to the problem is to have bit-width of each A[n] to be equal to maximum required bit-width i.e. W+N-1. However, this would mean that on synthesis same maximum sized signed adders of same bit-width are generated for each pair of input, potentially wasting circuit area.
