Ohm's law is valid for metals, but is it valid for semiconductors? Does it work there?
I am not talking about a PN junction here.
If I have a block of silicon and pass voltage across it, will I see current flowing, in accordance with Ohm's law?
Yes. All materials under normal conditions and at fixed temperature follow* ohm's law, though it becomes less useful in good insulators where breakdown occurs before any substantial amount of current can flow.
Non-ohmic effects occur at boundaries between different materials, such as pn junctions, schottky junctions, thermocouples, electrochemical cells, et cetera. They can also be observed in discharge phenomena, where the flow of current causes ionization and chemical changes in the conducting material.
*Here, "follow" means "behave in a way closely approximated by". Depending on how precisely you're measuring things, it may matter that it's not quite exact.
Edit: it's worth mentioning that the presence of (changing) magnetic fields can complicate things. Transformers and inductors are not generally considered to obey ohm's law under dynamic conditions, for instance.
For further information on where it gets murky, see this question.
Ohm's law is just an approximation. It says that voltage and current are linearly related with a constant called (DC) resistance. This may be true over a wide range of applied voltage, or only over a small range. In some cases the concept is used to describe small changes around a particular point (dynamic impedance -- R = dV/di around a particular bias point).
Metallic conductors follow it very well because the movement of electrons caused by reasonable currents is small compared to their pre-existing thermal random movements. If the current is so high that heating occurs, then 'Ohm's law' isn't followed exactly.
Semiconductors have more constraints. There can be a limited number of carriers available so their velocity is significant compared to thermal motion -- and then Ohm's law is not followed. In addition, higher voltages affect boundary conditions at the surfaces of the semiconductor and this also affects the DC resistance (large signal resistance).
