25
When working on high voltage power-lines via helicopter the technician will "bond-on" with a steel wand called a hot-stick. During this process an arc is conducted from the line to the wand. Now, since the helicopter is floating both literally and electrically, why is there any potential between the line and the wand?
My guess is that because of the alternating electric current in the power-line there is therefore an alternating expanding and collapsing magnetic field present in close proximity to the helicopter. This sets up a charge polarization in the frame of the helicopter 180 degrees out of phase with the current and therefore an electrical attraction occurs which produces an electric potential.
If this is true, even though the electrons are not free to move in a bird (as they are in the metal helicopter frame) they are able to rotate and still set up a charge polarization (much like a charged balloon sticks to a wall) and therefore when a bird "bonds-on" to a wire don't you think they feel a little tingle at first?
One other thing. Is it true that by virtue of the fact the the helicopter circuitry is an isolated one, they can bond-on to either line and that line will be the ground reference for the ground of the helicopter circuitry?
Salbando Jones
  • 331
This question is somewhat related to yours.
The phenomenon has nothing to do with magnetic fields. There is an intense electric field around any high-voltage wire (AC or DC), and the intensity is inversely proportional to the distance from the wire. At very close distances, the intensity exceeds the breakdown threshold for the air itself.
The presence of the conductive helicopter (and the repairman with his metal mesh suit) distorts this field, concentrating it even further in the space between the wire and the helicopter. When the bonding strap gets close enough, an arc forms. The current in this arc is limited by the overall capacitance of the helicopter.
Once the bonding connection has been made, the helicopter and the mesh suit are all at the same potential as the line itself. The electric field is still distorted, but now the concentrated areas are moved away from the repairman and the connection between the wire and the helicopter.
And regarding the birds, when have you ever seen a bird sitting on one of these high-tension transmission lines?
Dave Tweed
  • 168,369
  • 228
  • 393
    I don't know about the bird. I just figured that they sat on anything. So are you saying they don't? And if they don't, is it because they do feel a tingle as they get close and choose to fly away? – Salbando Jones Oct 12 '12 at 17:40
  • Yes, they can sense the intense field, and find it very uncomfortable. – Dave Tweed Oct 12 '12 at 17:45
  • @DaveTweed: I am wondering why the linesman needs to wear a mesh suit as a human is already a conducting object? – emnha Apr 04 '18 at 19:36
  • @anhnha: Because current flowing through a human can be uncomfortable, not to mention dangerous. – Dave Tweed Apr 04 '18 at 19:45
  • @DaveTweed: but when a human moves in a line, the resistance of the line is much smaller than human's resistance. So should the current flowing through human is very very small? – emnha Apr 04 '18 at 19:48
  • @anhnha: I'm not sure what you're talking about. The suit has nothing to do with the current that is flowing along the line. It's protecting the wearer from the capacitive current between the line and surrounding objects, including the helicopter. The E-field near the line is very intense, and the suit equalizes the voltage around the wearer, eliminating the field inside the suit. – Dave Tweed Apr 04 '18 at 20:02
  • @DaveTweed: I am considering human as a conductor with some resistance. However, this resistance is much larger than the live line resistance. So there is almost no voltage across the repairman (also almost no current flowing through body). I know the Faraday cage and its function but not sure what capacitive current you are talking. Why the current exist when there is no path (only capacitor between the person and line) with no ground connection? The bird is also also alive when stands on the live line without having to wear a metallic suit. – emnha Apr 04 '18 at 22:26
  • @DaveTweed: could you answer my question above? – emnha Apr 08 '18 at 21:03
  • @anhnha: Those questions have already been answered in what I wrote above. I have nothing further to say on the subject. We're just going around in circles now. – Dave Tweed Apr 08 '18 at 21:05
  • @DaveTweed: my question above is about the bird. It is similar to human but it is still alive without metallic case. Why human needs the case while bird not? – emnha Apr 08 '18 at 21:17
  • @anhnha: See the last paragraph of the answer, and the first two comments. Note that humans do NOT wear suits when working on the kinds of lines that birds actually sit on. – Dave Tweed Apr 08 '18 at 21:29
  • @DaveTweed: OK, I will accept that birds don't sit on that wire. So for lower voltage, say 200VAC then a human can sit on a single wire without wearing metallic suit? – emnha Apr 08 '18 at 21:37
  • @anhnha: Isn't that what I just said? Actually, humans don't "sit on" such wires at all; they work on them from insulated "bucket trucks". Also, such lines are usually de-energized when being worked on anyway. – Dave Tweed Apr 08 '18 at 21:40
  • @DaveTweed: you said that birds don't sit on that wire so I think you meant 500kV line. My question above is about 220VAC line, with this voltage I see a lot of birds sitting on the line and nothing happens. So will a human also safe sitting on a 220VAC line without a metallic suit? According to the link below, then it should be safe. https://www.allaboutcircuits.com/textbook/direct-current/chpt-3/shock-current-path/ – emnha Apr 09 '18 at 09:14
Even floating objects have capacitance. For example clouds which have huge capacitance and the charge equalization current ( cloud to cloud lightning) can be >> 10KA depending on the ionization path resistance. But heli's being a relatively "large bird" will conduct a fair amount of current to reach the same potential as the UHV line whether it is AC or DC. Once "bonded" the extremely low frequency 50/60Hz and mesh suits protect the operators. As an aside high electric fields of DC or ELF (extra low) have no detrimental effects on humans unlike RF from sustained arcing.
*added I read from ABB it costs $10k~20K to train an operator for live wire maintenance with 2 yrs prior experience at lower levels. So information is not freely available. They once relied on live hand connections since 1989 with a Faraday suit but now use the fiberglass rods with special conductors for connect and disconnect instead.. They don't specify details or differences between live servicing say 400 kVac lines vs UHVDC at 800 kVdc. I suspect servicing HVDC has the advantage of only having initial discharge/charge charge arc currents and DC leakage determined by dust and humidity, so I suspect servicing is limited when risk of rain is 0%. However AC lines may have more leakage due to capacitance to free-space of the Helicopter. Since the wavelengths are extremely long there is not much difference in electric fields, but as Dave said high gradients before contact. as there is in leakage current due to series capacitance of the rod to the body capacitance of the Heli.
end edit
More Aside notes... EMI affects humans roughly proportional to f until you get to infrared wavelengths then it picks up again starting with UV and continues to get even more sensitive to gamma ray wavelengths. I don't have the latest peer reviewed journals on non-ionizing risks, but there may be plenty of scare-ware reports. Microwave Engineers are extremely cautious about cell tower design to minimize risks to humans from dispersion to near field ground radiation and apartment spacing. Continuous exposure to Tesla generators with high current arcs are not good. Whereas low current plasma balls are harmless. Power Line operators are extremely careful about the cleanliness of their grounding safety rods that may reduce the dielectric strength.
I recall a Popular Electronics story decades ago, that warned people about AC power panels near bedrooms causing cancer in the home. I remember hearing circa Y2K that it was "fraud" and the perp. "scientist" was charged for defrauding the Gov't of grant money. Similar studies have been done on Cows. But the huge EM wavelengths create little potential risk to humans ( pun intended) HV lines are restricted from property development in most areas due to extreme weather on safety of fallen lines from Ice, tornadoes or hurricanes. Its not the HV ELF fields you have to worry about, but rather continuous arcing fields which contain RF, which if sustained can cause red eyes or worse fried brains in the case of Tank operators during WWII with high power transmitters behind their brain causing them to pass out to safety below deck.
So how much current does it take to charge up on connection? I think that would depend on the altitude & relative humidity and the coupling capacitance of air dielectric to the surface area of the floating "bird" capacitance is the other factor. So it is not truly "floating" unless you are a really tiny bird with no rotating "wings" that create also tribo-electric DC charges.
The altitude effect is relative to ground. As the chopper aproaches ground < 100ft it's capacitance increases rapidly from "free space" values thus as V=Q/C the charge Q results in a rapid decrease in voltage as C increases. In any case the landing feet touch first to discharge the bird and I have never heard of arcing on touch-down but this another question, but this effect reduces the risk.
    BTW, Airplanes steer wide of highly charged wet (dark) clouds due to pitting in the bearings of the turbine engines from stray discharge risks, which is a common occurrence and found during routine maintenance. Obviously the accumulation of pitting increases with exposure and intensity. The same is true with Chopper rotor and turbine bearings, but sand is even worse. – Tony Stewart EE75 Oct 12 '12 at 18:22
  • Do you have a citation for the WW2 tanker injuries? I never heard this before, and am not finding anything via Google. – Dan Is Fiddling By Firelight Oct 12 '12 at 21:19
  • I am not surprised it is not widespread knowledge. When I started working in the 70's in Aerospace, my Draftsman told me his personal experiences during the war as a radio operator and of tank commando leaders who scouted by visual aid standing up above the turret at the same height as the antenna. So they learned to duck when they were about to transmit. He didn't mention the details of which model but I believe WWII transmitters were in the range of 20 Watts of RF, just enough to cause problems if you happen to be near the peak of the standing wave but not immediately obvious or constant. – Tony Stewart EE75 Oct 13 '12 at 01:18
  • -1 - This answer not only fails to answer the original question, it is full of unrelated nonfactual information (heresay, speculation and personal opinion) that is way off-topic for this site. – Dave Tweed Oct 14 '12 at 15:27
    I understand Dave. Which part do you suspect is non-factual and unrelated? (apart from the obvious aside notes that may be unrelated to your expectations) I doubt anyone can answer for the birds if they feel tingling but the charge transfer and arcing is a matter of physics. – Tony Stewart EE75 Oct 14 '12 at 18:48
  • The big birds on the other hand with large wingspans apparently die from flash-over and one report indicated more die from this than those who are those hunted. – Tony Stewart EE75 Oct 14 '12 at 23:27
It's about accumulated charge. While the helicopter itself can accumulate charge (rotors moving past air) and the high voltage leads themselves possibly will have a dc voltage (transformers don't pass DC). There is an additional factor though that you may not be aware of, the very high voltage transmission lines can be DC.
Aerial proximity fuzes in anti-aircraft rounds work on these principles. As the shell approaches the aircraft the charge differential as expressed in the electric field is detectable. When a certain threshold is reached the bomb goes off.
placeholder
  • 29,982
  • 63
  • 110
  • Got here from a duplicate question. +1 for helicopters coming up to a charge. A big one. Ever seen the Hunt for Red October? There's a scene where a guy gets blasted by it. As a submariner myself, I can vouch for this. We have a corresponding ground wand for the helicopter to short to before personnel transfer. It's also why we only do it in extreme circumstances. –  Apr 28 '14 at 07:34
With regard to helicopters discharging as they touch down:
The passage of the rotary wings ("blades") through air is enough for them to build up a substantial static charge through friction with air molecules and for this reason alone if a hovering chopper drops a line, it's advisable to allow it to hit the ground before touching it.
Careless rescue personnel have been known to be knocked off their feet by the discharge, but it's not so much of a problem in wet weather (for obvious reasons)
The same thing happens on fixed-wing aircraft, which is why many have corona discharge wires on the trailing edge of their wings, for when the charges get to extreme levels.
Free-space coronal discharge is also known as "St Elmo's Fire" and can be quite damaging to an airframe.
See http://www.google.co.uk/patents/US3260893, which goes into a lot more detail about the phenomenon and mitigating it.
The visible arcing when bonding out is simple DC potential equalisation between the helicopter and the line (usually it's the helicopter at higher potential, bearing in mind that for AC lines the average potential of the lines is "ground level"). It's not particularly dangerous (only a few mA involved), but when you're that high off the ground you don't want anything to happen which might cause line staff to let go of whatever they're holding onto, should they get a jolt.
(If you think helicopter work is wild, some UK maintenance teams specialise in climbing towers and then climbing along the insulators onto live wires!)
