I'm using a TI CC1111 SoC to read/write a microSDHC SD card, with an Amphenol card socket. The card detect (CD) pin of the socket is connected to ground when no card is present. When a card is inserted, the connection is broken. (This seems to contradict the datasheet, but it's what my multimeter tells me).
One way to detect card insertion would be to connect a GPIO pin to the CD pin. By default the CC1111's pins are configured with an internal pull-up resistor. If a card were present, I'd read logic high, and otherwise the pin would be pulled to ground. But I worried this might draw excessive current, and sure enough, the CC1111 datasheet warns (pg. 90):
Unused I/O pins should have a defined level and not be left floating. One way to do
this is to leave the pin unconnected and configure the pin as a general purpose I/O
input with pull-up resistor. This is the default state of all pins after reset except
for P1_0 and P1_1 ... Alternatively the pin can be configured as a general
purpose I/O output. In both cases the pin should not be connected directly to VDD or
GND in order to avoid excessive power consumption.
Question 1: Where is the power consumed? Is it just in the internal pull-up resistor? The datasheet says the internal pull-ups are 20k, so with 3.3 V that's about 0.17 mA. Is that what they're talking about? Or perhaps the "excessive power consumption" warning only applies when the pin is configured as an output?
Qustion 2: What is the right way to detect card insertion/removal without wasting power?
And no, I haven't measured the current draw yet, but I will.
