I'd like to use Flash Magic to load programs onto my LPCXpresso1769 development board (https://www.embeddedartists.com/wp-content/uploads/2018/06/LPCXpresso1769_CD_revD.pdf), via ISP.
I purchased a USB to Serial data converter - TTLl-232R-3v3(https://www.ftdichip.com/Support/Documents/DataSheets/Cables/DS_TTL-232R_CABLES.pdf), and wired it up to the board as follows:
1) GND (FTDI Black) goes to J2-1.
2) TXD (FTDI Orange) goes to J2-22.
3) RXD (FTDI Yellow) goes to J2-21.
The board is powered via the USB debugger probe
I enter ISP mode in the typical way, although it appears that the RESET button on the board is actually the ISP button, and vice versa (can anyone confirm this?), so I tried both combinations to make sure I was entering ISP mode.
In Flash Magic, I tried all available COM ports, and a range of baud rates, with the clock set to 12Mhz. I tried to establish a connection by using Read Signature, and on all occasions, a "Failed to transmit or receive", or, "Auto-baud" error was displayed. Is there anything glaringly obvious I'm doing wrong?
19172281
  • 685
I've finally sorted the problem.
It appears that the board needs to be powered externally (i.e. not via the debug probe/usb)
19172281
  • 685
