While I would love to dive into the various programming methods available, someone else already has. Here is Dean Camera's tutorial on AVRFreaks, AVR Programming Methods:
There are many ways to program AVR
microcontrollers. Since many people
ask about different ones at one time
or another, I thought I'd outline them
here so that their questions can be
answered quickly and efficiently.
Please forgive me if I miss a method
or make an error.
METHOD 1: In System Programming (ISP)
Supported By: Vast majority of AVRs (see below posts)
Supported Programmers: AVRISP MKI/II, JTAG MKII, STK500, STK600,
Dragon, AVRISP clones, AVR910 Programmers, AVRONE
In System
Programming is perhaps the most common
method of programming the flash,
EEPROM, fuse and lockbytes of the
entire AVR line. ISP can program AVRs
at extremely high clock rates
(assuming the target AVR is running at
a high frequency and the programmer
supports it) and is the method of
choice for almost all AVR hobbyists.
There are many, many AVRISP clones and
AVR910 programmers on the market in
addition to simple do-it-yourself
dongles which connect to your
computer's parallel port.
Recent new dongle designs may use the
computer's serial port, however
anecdotal evidence has said that this
method is extremely slow due to
technical limitations.
ISP requires that the target AVR is
running at a clock rate of at least
four times that of the ISP clock. This
is a common pitfall and a source of
confusion to many new to AVRs.
METHOD 2: JTAG
Supported By: See AVRStudio Tools help for MKI and MKII device support
Supported Programmers: JTAG-ICE, JTAG-ICE MKII, Dragon, JTAG-ICE
clones, AVRONE, STK600 (programming only)
Technically JTAG is a
debugging system, not a programming
method. Still, the JTAG interface
allows for the programming of an AVR
which supports it.
JTAG is an in-system debugging tool
which allows you to manipulate and
examine the status of a supported AVR
while it is running in a circuit. JTAG
allows the user to stop execution at
any time, the manipulation of the
AVR's internal registers and much
more.
The official JTAG-ICE units from ATMEL
have been superseded by the JTAG-ICE
MKII, which supports the newer and
more widely supported across the AVR
range DebugWire debugging protocol as
well as programming via the ISP method
(see above).
JTAG-ICE clones are available for low
prices, however their limited
compatibility with only a handful of
AVRs limits their usefulness.
Regardless of this, if your AVR
supports the JTAG interface the
JTAG-ICE remains a very nice and
effective debugging method and
programmer.
METHOD 3: DebugWire
Supported By: Many smaller AVRs
Supported Programmers: JTAG-ICE MKII, Dragon, AVRONE
Again DebugWire
is a debugging rather than a
programming interface, but can be used
to load in programs into supported
AVRs. The dW interface uses a single
AVR pin (the /RESET line) for all
communications, making it ideal for
the low-pin count AVR devices.
METHOD 4: Bootloader
Supported By: Most newer AVRs
Supported Programmers: N/A
Again technically not a programming method.
A bootloader is a small AVR program
which sits in a user-settable reserved
section of the regular flash.
Bootloaders make use of the flash
self-modification features available
in the newer AVRs to allow the AVR to
program itself via program data loaded
from an external source. Bootloaders
may source their data from any
location (eg external dataflash or SD
card) however by far the most common
type of Bootloader communicates with a
PC via the AVR's RS-232 (serial) port.
Bootloaders are limited in that they
do consume flash space (limiting the
size of the flash available to the
AVR's application) and they are unable
to change the AVRs fusebits.
Bootloaders are widely available on
the internet for download, but they
suffer from a "chicken and egg"
problem; you need another type of
programmer listed here to program in
the bootloader in the first place.
This is usually solved by the
construction of a simple parallel port
dongle (See ISP section) or by the
purchase of an AVR already preloaded
with a bootloader (eg the AVRButterfly
board).
METHOD 5: High Voltage Parallel Programming (HVPP)
Supported By: Most non-TINY AVRs (with exceptions)
Supported Programmers: STK500, STK600, Dragon, Homebrew Dongles,
AVRONE
Programming is a method of programming
which is rarely used, because of the
hassle it requires to set up. Despite
this, HVPP programming is commonly
used to "resurrect" AVRs whose
fusebits have been mis configured via
another programming method.
Both the STK500 and the Dragon
supports HVPP. During HVPP, the
target's /RESET pin is raised to the
unusually high value of 12V which
engages the internal parallel
programming circuitry. The /RESET pin
is the only pin of the AVR (on HVPP
supported AVRs) which can be safely
raised to this level.
You can make your own HVPP dongle
using online plans such as this one.
METHOD 6: High Voltage Serial Programming (HVSP)
Supported By: Many TINY AVRs (with exceptions)
AVRONE
HVSP is similar to HVPP,
except the data transfer is performed
serially rather than in parallel. This
is the alternate programming method
used on many TINY series AVRs who lack
enough pins for HVPP.
METHOD 7: PDI
Supported By: XMEGA AVRs
Supported Programmers: STK600, AVRONE, JTAG MKII, Dragon, AVRISP MKII
PDI is the new programming interface
based on the debugWire protocol, for
the XMEGA line of AVRs. It's not
currently used on any other 8-bit AVR
microcontrollers.
METHOD 8: TPI
Supported By: 6-Pin TINY AVRs (ATTINY10, etc.)
Supported Programmers: STK600, Dragon, AVRISP MKII
TPI is a very
tiny programming interface for the
newer TINY line of AVRs with limited
pins, like the 6 pin ATTINY10. Like
dW, TPI uses the device's /RESET line
as part of the communication
interface, but there the similarity
ends. Since the pint-sized TINY AVRs
lack a on-chip debugging circuit, the
TPI protocol uses a new programming
interface of three pins, in a
half-duplex protocol. Because the
/RESET line needs to be raised to +12V
for programming when the device's
RSTDSB pin is set, this is currently
only supported by the newer STK600
programming board.
Bonus FAQ Section!
Which is the best method?
There is no universal "best" method. ISP
programming is simple and extremely
popular, however all the above methods
will work. The two high voltage
programming modes (whichever is
applicable to your device) are the
most feature rich, as they allow for
the repair of an AVR which has had its
fuses misconfigured. However, those
methods are a pain to set up, hence
the reason most users go with with
ISP.
I've made a parallel port dongle. Can I use it with AVRStudio?
I'm
afraid not. AVRStudio cannot interface
with any "dumb" dongles - it requires
a smart programming device -
containing a microcontroller itself -
to decipher the communication protocol
it sends. Simple dongles without a
microcontroller must be "bit-banged"
(ie. the appropriate signals simulated
through the dongle via the computer)
itself.
So my dongle's useless then?
No. You can still program through a
home made dongle with a third party
programming software tool. AVRDude is
a good, known, free command line
utility - and it comes included with
the WinAVR package.
What are my options if I want my programmer to work with AVRStudio?
Choose a programmer that uses an
AVRStudio-supported protocol. This can
be the simple "AVR910" protocol
(deprecated) or a custom
implementation of the protocol used by
the STK500/AVRISP. Note that these
programmers require a micro controller
in them, leading to a catch-22
situation. This may be solved by
having the programmer's AVR
pre-programmed at time of purchase
with the appropriate firmware, or by
having the AVR pre-programmed with a
bootloader.
Ok, I want to use a bootloader. How do I get it in there in the first
place?!
To use a bootloader in an
AVR, you first have to have the
bootloader programmed in. If you do
not have an existing programmer (even
a simple dumb dongle will suffice for
the initial programming), you can
alternatively purchase AVRs
pre-programmed with a bootloader from
several suppliers.
Atmel
also manufactures the Butterfly demo
board, whose MEGA169 AVR comes
pre-loaded with an AVR-Studio
compatible bootloader.
Help! I've messed with the fuses and knackered my AVR while using ISP!
The most common mistake is changing
the clock selection fuses to an
invalid setting. Try putting an
external clock on the AVR's XTAL1 pin
and see if that helps.
Failing that, if possible use one of
the high-voltage methods. These will
fix any misconfiguration, including
ones involving the clock source as the
high-voltage methods provides its own
clock to the AVR for programming.
How do I interface with my programmer?
Which software you use
to interface with your programmer
depends on the type of programmer you
are using.
Simple "dumb"
dongles require third party software,
such as PonyProg or AVRDude. These may
be command line or GUI tools - look
around on the web and you will fine
one to fit your needs.
Programmers and bootloaders based on
the AVR910 protocol can be used within
AVRStudio. From the Tools menu, select
the "AVRProg" option to open up a GUI
screen to interface with your
programmer. As an alternative, third
party tools such as AVRDude are also
AVR910 compatible.
Official
tools are tightly integrated into
AVRStudio, especially in the case of
the debugging variants
(JTAG/Dragon/etc). From the AVRStudio
Tools menu, select the "Program
AVR..." submenu and click the
"Connect" item. From the new window,
select your tool and its connection
interface and click ok.
As
is the case with the dumb dongles and
AVR910 programmers, the official tools
may also be used with third party
programming software.
(C) Dean Camera, 2009. All rights
reserved. Not for reproduction on any
website other than AVRFreaks.net
without prior explicit
permission.
