I want to make a circuit with an output impedance of 50 ohms.
I am dealing with negative photomultiplier tube pulses that in 50 ohm load look like in the picture below:
I want to use the pulses to trigger the one shot sub-circuit described here which uses positive signals:
I understand that I must use a simple sub-circuit with an inverting fast operational amplifier.
Is it possible to make the op-amp sub circuit have an \$ Z_{out} \$ = 50 ohm so it can drive the one shot sub-circuit?
Maxim
  • 475
Chris Sy
  • 147
    Andy's advice is spot on for Zo, however you can modify the one-shot to accept negative input pulses – sstobbe Apr 15 '19 at 19:00
  • @sstobbe hello and thank you for commenting , such a modification would that would be very good . Do you have any suggestion how yo modify it ? Best regards. – Chris Sy Apr 16 '19 at 02:15
  • Hello! I am really interested in this question since I am facing the exact same issue. How did you end up solving it? We're you able to finally detect the PMT pulses? – user3141592 Mar 24 '23 at 14:34
Is it possible to make the op-amp sub circuit have an Zout = 50 ohm so it can drive the one shot sub-circuit?
A basic op-amp circuit is usually one where its natural output impedance is close to zero ohms but, this is only true at low frequencies. For instance, a "normal" op-amp circuit might start to have significant output impedance as frequency rises above (say) 1 MHz. This is dictated by the data sheet i.e. faster op-amps will maintain a lower output impedance for higher frequencies but there will always be a tipping-point and you (as the designer) have to decide how to tackle this.
For your one-shot circuit I see that the amplitude required at the input can be a few tens of milli volts and this helps a lot because you can use a potential divider on the output of the op-amp to convert a naturally high voltage (like a pulse of 2 volts p-p for instance) to a signal level 20 mV p-p.
This requires an attenuation of 100:1 so, if you used 5000 ohms and 50 ohms to give an approximate attenuation of 100:1 you get a natural output impedance of about 50 ohms irrespective of what the op-amp circuit might be struggling to deliver.
  • Hello and thank you for answering, i don't seem to understand you mean i should connect the output of the opamp to a 5k and 50 ohm resistors in series and connect the point above the 50 ohm to the one shot input ? ( it seems i can't use images in comments to show you what i understand , sorry about that) – Chris Sy Apr 15 '19 at 09:36
    Yes, that's what I'm suggesting - your op-amp should be able to deliver a couple of volts pulse to the attenuator and the attenuator will deliver 20 mV p-p to your one-shot circuit. You would probably get-away with a 4k7 resistor directly feeding the 49.9 ohms on the one-shot circuit. It won't be critical if wire lengths are short. – Andy aka Apr 15 '19 at 10:02
