I have a 5V 1500 mA charging/power cord for a camera that was too short to reach the mounting position I need, so at the suggestion of my electrical engineer father, I decided to try to lengthen it. He said to just twist and tape the wires together but I wanted a sleeker look so I decided to try soldering and heat shrinking. The cord will be left plugged in and powering the camera 24/7. The original cord is 20 awg but the closest I could find was 4 extra feet of 18 awg lamp cord (2 wires in both). So I cut the original, stripped the 4 ends between 1/4 - 1/2 inch back, spread the strands out, butted and twisted them.
Next, I soldered them together and this is the part I feel uncomfortable with. For starters this was only like my second time ever soldering and the first time with this iron. The first joint looked ok, maybe slightly light on solder - it didn’t flow very well - but it was holding together against a gentle tug. The second was my worst joint, it ended up with a little too much solder and kind of thick. I figured out that my iron wasn’t hot enough even though it was set at about 380-390. After turning up the heat, it flowed into the next two, but the tips of the insulation on the original wire melted a tad (see photo). Is that bad?
3rd & 4th joint
Next I applied heat shrink over each individual joint. The heat shrink seemed a little thin so I also wrapped a little electrical tape around one joint on each end of the spliced length for extra insulation. Then I applied larger heat shrink over both wires together on each end. Then finished it off with white electrical tape just to match the cord color.
Charger final wrap
My question is, is this safe to use? I tried plugging it in and the device indicates it is charging. I feel pretty confident it’s not going to short with two layers of heat shrink and electrical tape separating the conductors. But being a novice, I’m just looking at my taped up cord picturing a fireman holding it up for a look in the remains of my burnt home. I’m most worried my solder joints aren’t good enough and might cause a dangerous resistive connection.
xr280xr
  • 203
    Is this connection on the 5V line? Then i see no problem with this, the soldering you did looks good and sturdy. How much longer did you make the wire? There could be some problems with voltage loss, but if it indicate that it is charging then i guess it's not a big deal. – Linkyyy Apr 13 '19 at 08:21
    Looks good. I would have personally staggered the joints slightly, so that they were not directly next to each other. – HandyHowie Apr 13 '19 at 09:05
    Linkyyy, I added 4 ft. I have another identical, unmodified Charger. Can I compare the output with a multimeter? HandyHowie, good idea, I didn’t think of that. Thanks! – xr280xr Apr 13 '19 at 13:28
    @xr280xr To be useful voltage comparisons would need to be made under load. – Russell McMahon Apr 13 '19 at 13:37
  • It works, so it's ok. But you should aim to keep the low-voltage, high-loss part as short as possible, and instead extend the high-voltage, low-loss part. Which is trivial with a right extension cord, but of course not always possible. – Agent_L Apr 13 '19 at 16:30
    If you follow House's advice and stagger the joints, you can also make a much sleeker look by eliminating the heat shrink between the wires. Shouldn't matter for 5V or over heat shrink, but just FYI, white tape is only rated to insulate if it bears appropriate markings inside the roll(CSA, UL or the like). – K H Apr 13 '19 at 20:40
    The solder provides the electrical connection. You can see if it is effective by measuring the voltage drop across the splice. You should not drop more than 0.10 V, if I recall correctly. The twisted wires provide the mechanical connection but it is not very strong. I think you should have crimped to provide a mechanical connection that would be resilient to to flexing, twisting and pulling. (In the past I had to perform a similar repair on a truck. The main engine harness was mechanically crimped, and voltage drops caused rough idles. I needed to soldier to improve the electrical connection). – jww Apr 14 '19 at 03:51
  • See addition to my answer re strain relief. – Russell McMahon Apr 15 '19 at 09:39
    @jww and xr280xr - crimp connectors that are correctly crimped with factory specified tools usually provide good quality results. But, crimp connection with after market tools - even ones that appear to produce a good result, may result in high loss and unreliable connections. I have seen the results of such crimping in a vehicle fleet where various installers created apparently good connections that subsequently gave trouble. I consequently always solder such connectors post crimping if there is any doubt whatsoever re crimp efficacy. – Russell McMahon Apr 15 '19 at 09:45
  • Related: Vehicle jumper leads are almost invariably crimped and not soldered. The crimps are usually abysmal. I always solder any jumper leads I use. – Russell McMahon Apr 15 '19 at 09:45
For a first attempt you have achieved an excellent result.
The result should be safe and reliable. Cosmetically the result could be somewhat better but I have seen far far far worse in use and working long term.
The key points to consider are:
  • The output wires should connect to the same input wires as they did before the extension was made. Yours obviously do as the charger charges. However, this is an easy thing to get wrong and people sometimes do. The result may be as minor as "won't work" or as major as "charged device and/or charger destroyed".
    It pays to establish some way of determining which is the right and wrong way of connecting the wires. This is even more crucial when there are more than two wires.
    You obviously got it right :-).
  • The connections should be mechanically robust and not rely on the solder for strength.
    You got it right.
  • The solder joints should meet guidelines for good joints.
    Solder should flow and "wet" wire in both joined wires, be of correct appearance (smooth and shiny for lead 60-40 solder, less shiny for lead free solder) wires. Not too much and not too little solder.
    You did well enough.
    Your competence will improve with experience.
  • The insulation should cover each bare conductor separately and completely. Yours does.
    You did not show the heatshrink. It should extend past the conductor at both ends and when shrunk should not be mechanically removable without destroying it.
  • The outer insulator should be robust enough to maintain overall insulation integrity for more than the desired lifetime of the connection.
    Yours sounds good. The outer tape MAY fray and unwind somewhat over time but the inner large heatshrink should render this unimportant.
The most significant improvement you could aim at is improving the joining of the two wires. What you have done is entirely acceptable - but, the bare wire outside the joint proper serves no great purpose. This can occur due to insulation pullback/shrinkage when soldering. This is minimised by learning to solder faster :-).
A way to minimise join length is to decide how many wraps each wire will make around the other 'target wire", decide how much target wire length is needed, and start winding one wire around the other at the desired length away from the target wire's insulation - ie usually quire close. When both wires have been wrapped onto their "target" wires there is no bare exposed wire between the join and insulation on either wire.
Mention was made of possible breakage at the end of the stiff solder sections and that strain relief in this area may help longevity.
This is a valid concern but unlikely to cause a short to medium term problem in normal use with normal handling. If you want to retrofit strain relief you can do so by taping or shrink tube fixing a stiff or semistiff stick/rod to the outside of the join such that it protrudes beyond the stiff soldered portion at either end. The wire leaving this portion is flexible and less liable to fatigue. Allow a small length at either end where the rod is not bonded to the wire so it exits with minimum stress.
Russell McMahon
  • 147,325
  • 210
  • 386
    The joint looks fine, but one issue not mentioned in this answer is that because the soldered joints are much stiffer than the rest of the power cord, if the cord is regularly bent or pulled the wires are likely to eventually snap at the end of the soldered section. If this likely to be a problem, you would be better using something like a simple in-line switch (e.g. https://www.ebay.co.uk/b/Inline-Cord-Switch-in-Home-Electrical-Fittings/57215/bn_7022674808 to join the wires.You could fix the switch permanently in the "on" position, of course. – alephzero Apr 13 '19 at 11:52
  • Great information! Just what I was looking for. In my case the original cord had a dashed line marking on one wire and the lamp cord had a rounded edge for one wire so I used those to keep track of the routing. I did overlap the heat shrink and it is very tight. I’ll try your advice next time. I had trouble twisting the wires all the way to the base because of the double wires and because I didn’t measure them exactly. Alephzero thanks for that point. It will be fixed to a wall. – xr280xr Apr 13 '19 at 13:39
    Great answer. One thing I would add is, whether or not a novice can do it depends on the wire used, because that can vary. The wire pictured here looks like a good gauge wire with good insulation, but some 5v charging cables are pretty low quality and nearly impossible to even prep for soldering. – dogoncouch Apr 13 '19 at 18:38
    You can also provide strain relief for a stiff soldered connection by staggering the joints, a layer of heat shrink over each joint, a spring(plastic if voltage was significant) and a second layer of heat shrink over the lot. If you weren't using the electrical tape for color, I'd say put it under the heat shrink for a seamless look. The main problem with electrical tape is long term stability/unwrapping and this prevents that. – K H Apr 13 '19 at 20:48
  • @KH wish I had thought of that. I have some clear heat shrink. – xr280xr Apr 14 '19 at 03:09
  • To provide extra protection, cut of both leads at different lengths, that way, even if all the tape and heat shrink fails, the wires are still unable to touch each other (and the insulation has usually an higher breakdown voltage) – Ferrybig Oct 14 '19 at 14:18
You did fine. The only thing I would have done different is to offset the two joints so that they are not adjacent. Sometimes the wire wears or pokes through the shrink wrap, and you don't want it to contact the other wire (unless you like fireworks). Offsetting the two joints prevents this. A third large shrink wrap around the whole thing might be a good idea.
Electrical engineers do not necessarily know how to solder. I am one, and the only reason I can solder is that I am also a radio ham. In the first three quarters of the last century radio hams built their own gear and soldered quite a bit.
richard1941
  • 632
