56
We've all seen this scenario in movies; somebody has to cross a room half filled with water and there is a dangling electric wire that shoots sparks everywhere. The poor person has to cross the room but cannot do so because if the wire hits the water he is obviously electrocuted since water is a conductor.
But is it so simple in real life? If I'm really standing in water in a room, and a high voltage wire hits the water, how does the electricity flow through me to electrocute me? Only my feet are touching the water, no other bodypart of mine is touching anywhere. And realistically there probably would be some piping etc. connected to ground somewhere that would conduct the current to ground. How would I be electrocuted if the current just flows past me?
I suspect this is similar to the well known situation of somebody dropping a hair dryer into a bathtub with a person in it. Why doesn't the current in this situation flow either from the live wire to the neutral wire or through the drain to the ground? Why does simply being in "high voltage water" electrocute me? (And yes, I know the scenario is not so likely with modern appliances but let's consider this in theory).
S. Rotos
  • 3,197
  • 47
    I seriously suggest that you **don’t** do any testing. – Solar Mike Apr 08 '19 at 11:20
    The answer is: **it depends**, there are **many** variables involved like: distance between you and the wire, voltage on the wire, conductivity of the water, water level, material of the bath, if the bath is metal or conductive: how well is it grounded, is it painted. I could go on for a while. All this determines the amount of current passing through the person. Also thin persons can handle less current than "less thin" persons. There can be no clear answer. – Bimpelrekkie Apr 08 '19 at 11:26
  • Your ground symbol in the sketch implies that the power on the wire is referenced to ground. It may not be. The power on that line could be isolated from ground. – scorpdaddy Apr 08 '19 at 12:28
    This question reminded me of the following video on Youtube made by Electroboom: https://www.youtube.com/watch?v=dcrY59nGxBg Where he actually does an experiment to confirm this – Ferrybig Apr 08 '19 at 18:32
    "There's an exposed wire over the bathtub ... Oh yeah! Shock wire! I call it that 'cause if you take a shower and touch it.....YOU DIE!" - Ron Swanson / Andy Dwyer - Parks and Rec – NKCampbell Apr 08 '19 at 18:46
  • [Relevant recent link](https://abcnews.go.com/US/teenagers-electrocuted-rescue-dog-canal/story?id=62139277). (Similar happens quite often.) – Brock Adams Apr 09 '19 at 05:06
  • @BrockAdams it's probably too soon to tell in this case, but what tends to be the cause? Live bridge and earthed water of vice versa? I'd expect a metal bridge to have a reasonable path to ground though it's possible it could be isolated by concrete foundations. I've never heard of this (canal/river/lake electrocution) happening in the UK. – Chris H Apr 09 '19 at 08:10
  • Is this a suicidal version of xkcd? – smci Apr 09 '19 at 11:36
  • @ChrisH, of the 4 recent, local to me, cases I know about: 1 was "poor grounding", 2 were hot wires touching something metal, and 1 didn't report enough data. I don't know why there is a massive evil cover-up of similar cases in the UK. ;) – Brock Adams Apr 09 '19 at 14:33
  • @BrockAdams it seems to me you should need 2 failures: both poor grounding and a live wire where there shoudln't be one. I guess the poor grounding could be because non-electrical metalwork doesn't always need to be grounded, and if a live cable was expected to carry a lot of current nothing would blow if it came adrift. I've tried and can't find any UK case reports of open-water electrocution at all; electrocution is such a rare cause of death it's off the bottom of the chart in many sets of statistics – Chris H Apr 09 '19 at 15:01
  • I suppose if you hop on one leg and don't touch anything and are not overly ticklish (which would make you fall down, spasm and drown) you should be fine. – Peter - Reinstate Monica Apr 10 '19 at 09:28
  • +1 for the sketch! – dalearn Apr 10 '19 at 11:19
7 Answers7
63
Oh yes. The phenomenon is called "Electrical Drowning".
In this tragic case, a girl decided to dance in a fountain, unawares that the underwater lights had a ground fault. Her muscles contracted and she fell down. One friend went in to try to grab her, and she too lost control of her leg muscles and fell down. Her two other friends tried to rescue the first two.
Firefighters showed up, one tiptoed in, lost it and his friends yanked him out. The firefighters spent 15 minutes trying to find the shutoff switch.
The problem with falling down in water is that you drown. All four girls did.
In fact, multiple victims is often the only clue to an electrical drowning.
This is why any beachside installations now require GFCI and shutoff switches, and why you should not swim near a boat on shore power.
Why electrical drownings happen
You've seen problems involving grids of resistors. That's what water is, a 3-D grid of resistors, and you also are some of the resistors.
Electrical current travels all available paths in proportion to their conductance (1/resistance). 1-10 mA is enough to start causing problems for a sensitive person; 100 mA is lethal in its own right.
Electricity wants to get back to source (the pole transformer's neutral), and the NEC standard for a grounding rod is 25 ohms. You can do the math here.
Well, I get 120 V through a 24 ohm resistor = 5 amperes. So only a tiny fraction of that current need go through you to nail you. If we rely on that article's 20 mA, then 1/250 of the current is enough to drown you.
Note also: this is not nearly enough to trip a typical 13, 15, 16 or 20 A branch circuit breaker.
However, a GFCI breaker will trip at 6-8 mA. That greatly improves the prognosis. This narrows it down to a highly improbable combination of events where the current is naturally limited to less than 6 mA, and almost all goes through you, and you're ultra-sensitive.
Peter Mortensen
  • 1,676
    Many such cases, like [this one](https://abcnews.go.com/US/teenagers-electrocuted-rescue-dog-canal/story?id=62139277), don't involve drowning. The current stops the heart (and other things). – Brock Adams Apr 09 '19 at 05:10
    "That's what water is, a 3-D grid of resistors, and you also are some of the resistors." Best analogy I have ever seen to describe this issue. Bravo! – JRaef Apr 10 '19 at 01:03
    One additional point: Compared to fresh water, the human body is a particularly low resistance path, so the current will preferentially go through you. – Martin Bonner supports Monica Apr 10 '19 at 10:37
    Then how do you explain this? https://www.youtube.com/watch?v=dcrY59nGxBg – Chloe Apr 10 '19 at 19:04
    @Chloe Did not watch the whole video, but in that case, the only conductive parts are contained within the toaster - the outside of the bath is non-conductive (with the possible exception of the plughole). As concrete is conductive, the bottom of any fountain or pool is likely to be a decent ground. – SomeoneSomewhereSupportsMonica Apr 11 '19 at 06:11
  • Concrete isn't *conductive* conductive, it's a lot like water or dirt. More resistors. – Harper - Reinstate Monica Apr 11 '19 at 08:33
  • I would highlight that in the specific example given - the answer is unlikely. Ground is positioned between the person and the cable and as such very little current will run through the person. There are many videos on YT of people showing this effect (although not usually with their entire body because of the risks!) – UKMonkey Apr 11 '19 at 10:02
  • @UKMonkey as I discuss, "very little current" is more than enough. Current follows **all** paths in proportion to their *conductance*. Given how little current will disable a human, you need a *whole lot of conductance* to divert essentially all the current. *How much* conductance is something NFPA spends a lot of time thinking about, and the result is the Electrical Code's specs on grounding. Though I'm not sure of your context, I didn't see that video, it is behind a signupwall. – Harper - Reinstate Monica Apr 11 '19 at 17:27
    I'm not an EE, but this seems like a good explanation to me. And for anybody still skeptical, a man was electrocuted (did not drown) this way in front of my father and others I knew, in a shallow pool of water that had a live wire dangling in it. I don't recall the voltages involved; it was in an oil refinery. – Flynn Apr 11 '19 at 18:18
  • The other thing about electric shock is it's *so damn unpredictable*. Probably because it involves "random in-the-worlld" materials and conditions. Those affect the relative conductance of the human vs. other current paths. So somebody can do a stupid electricity trick and live, and another can die. I hear one experimenter killed himself with 9VDC on opposite hands, because he stuck himself with needles as the terminals. So **don't tempt fate**. – Harper - Reinstate Monica Apr 11 '19 at 19:21
  • How do you explain this when your skin has a resistance of 1000 Ohms? – Chloe Apr 11 '19 at 19:21
    @Chloe Skeptical that it's ever that *consistent* (not least, skin is not linear), but suppose that's true. R=2000 ohms (enter *and* exit). My linked article cites injurious current to be I=20ma. E=IR. E=40 V. 40V can deliver 20ma through 2Kohm. *Now that you mention it, different governing agencies have different cutoffs for the liberal low-voltage wiring rules, but they all are near 40V*. Hmm! – Harper - Reinstate Monica Apr 11 '19 at 19:30
30
In something like water electricity does not "flow to ground" in a neat straight line. There is a potential difference between sections of water radiating out from the HV contact point. That might also mean that your feet are at different potentials, and there will be current flow which could be fatal. This is one reason why cows in fields can be electrocuted by a nearby lightning strike. The voltage difference between their feet can be thousands of volts.
Dirk Bruere
  • 13,425
  • 53
  • 111
    It also might not flow to ground at all. If the dangling wire, for example, was connected to a UK shaver outlet (powered by an isolation transformer) then the only available path is back the other wire to the other side of the transformer. – J... Apr 08 '19 at 17:58
  • Yes, this. There is currently flowing out in all directions to different grounding points. If somehow floor was non-conducting and very well isolated except for a single very good ground very near the wire then most of the room might be safe, but I’m not gonna be the one to verify that. – John Hascall Apr 08 '19 at 22:22
    Even humans can be electrocuted by a nearby lightning strike. Paradoxically, there are many aspects of a strike that are _worse_ if it hits the ground near you than if it hits you directly (the former can stop your heart if the electrical potential is great enough, whereas the latter "just" causes burns and lung damage). – forest Apr 08 '19 at 23:44
    Especially considering that most water you encounter day-to-day is fresh water. The human body is saltwater, which has a lower resistance, so electricity will preferentially flow through you. – skyler Apr 09 '19 at 19:02
    Regarding potential differences on the ground in a lightning strike: That's why you should have your feet close together (to minimize the potential difference between them and hence the current flowing through them) while you squat (to minimize the chances of a direct hit which would at least give you an [instant new tatoo](https://www.nbcnews.com/healthmain/heres-what-lightning-strike-can-do-your-skin-325006)). – Peter - Reinstate Monica Apr 10 '19 at 09:26
    @PeterA.Schneider Does squatting really do anything? I was under the impression that the height of a human on normal terrain doesn't have a significant effect on the leader trajectory. – forest Apr 11 '19 at 06:07
  • @forest It may only be Voodoo but I have heard it as advice (plus the feet close togther). – Peter - Reinstate Monica Apr 11 '19 at 08:41
16
I think that the answer is pretty simple - you are a better conductor than fresh water. I read this somewhere and it made me giggle then: "Humans are just big bags of salt water", which is true. A current of 1 mA through the heart is enough to cause a heart attack, so at 220 V, 220 kΩ resistance is not enough. You are less than 220 kΩ, especially when in water. Skin is the only insulator we have.
Just don't try it.
Peter Mortensen
  • 1,676
Willy Wonka
  • 779
  • Yup, this is how you can get electrocuted--you have a considerably lower resistance than fresh water so if your body can be used to go to the ground it will--the current is happy to flow up one leg and down the other. – Loren Pechtel Apr 09 '19 at 03:28
    Actually this is wrong: the worst shock will happen in a slightly salty water with the same conductance as a human body. Think about impedance matching: maximum power transfer happens when Zload=Zsource. – Dmitry Grigoryev Apr 09 '19 at 13:48
  • @DmitryGrigoryev You are right. – Willy Wonka Apr 09 '19 at 14:54
    @DmitryGrigoryev: Maximum power transfer *when the voltage is regulated* happens for a matched load. Therefore, replace the source by its Thevenin equivalent, and the load should be the conjugate of the Thevenin-equivalent series impedance. That's totally unrelated to impedance equaling that of the water it displaces -- you're matching to the wrong part of the circuit. (Another statement of the issue, you are matching *resistivity* when you should be matching *resistance*) – Ben Voigt Apr 10 '19 at 05:21
    "Ugly bags of mostly water!" You made me remember a little bit of Star Trek humor. – enorl76 Apr 10 '19 at 18:05
  • @BenVoigt I'm not matching anything to anything, I'm saying this is *similar* to impedance matching, but obviously not in every detail. The main point is still valid though: if you want to maximize the ratio of power dissipated in the body, you need to use the electrolyte with the same specific conductivity as the body. – Dmitry Grigoryev Apr 11 '19 at 09:14
  • "if you want to maximize the ratio of power dissipated in the body, you need to use the electrolyte with the same specific conductivity as the body" No, you don't. Same conductivity guaranteed same resistivity but does not guarantee same impedance. Because the water outside the body and the volume displaced by the body are not the same shape. Also, that rule of thumb comes from finding the load that maximizes power transfer, when the Thevenin source resistance is held constant. But **in this case the load is held constant, and lower source resistance means more power to the load**. – Ben Voigt Apr 11 '19 at 13:35
13
I already posted that picture once in a question about electric eels:
enter image description here Source: phys.org Credit: Kenneth Catania
Electricity doesn't flow along a single preferred path, it flows in the entire water body with different intensities. If you happen to be in a path with high enough current, you'll get electrocuted.
An interesting corollary to this fact is that you'll get the worst shock when you and the water have comparable conductance. If the water is much more conductive than you, even high currents will only create a small voltage difference, which may not be harmful. If the water is much less conductive, the voltage difference may be huge, but the current will be limited.
Dmitry Grigoryev
  • 25,576
  • 45
  • 106
  • That's a nice illustration of a tricky concept. –  Apr 09 '19 at 14:54
    The current flowing through a body in water depends solely on its resistance and the sustained voltage, not (directly) on the resistance of the sorrounding water. The caveat "directly" is because a high resistance surrounding makes the potential difference at your body collapse (it happens in the high resistance part, and the current through your body making that drop happen may not be harmful). But the case that your body has a *higher* resistance than the surrounding won't have any benefit at all. (You'd need a power source though which can sustain the voltage in spite of the high currents.) – Peter - Reinstate Monica Apr 10 '19 at 09:59
  • "If the water is much more conductive than you, even high currents will only create a small voltage difference". I wonder if this is really the case. If we assume that there is a fixed voltage source that can produce any current needed, than a change in conductivity will have no influence on the total voltage potential. Lets look at the case where the body resistance is much larger than the water resistance. If the total voltage potential stays the same (and the water has uniform conductivity), then the voltage drop over a smaller section would also stay the same. ... – BrtH Aug 02 '19 at 21:08
  • ... Only when the resistance of the body is in the same range or smaller than that of the water, the voltage drop would change, because there is no more uniform conductivity. However, the voltage drop only lowers, and with it the current through the human. See this simulation: https://i.imgur.com/Cv9pVMW.png, the current through the human is the largest when the resistance of the water is smallest. This also holds when we use a different ratio of the resistances of R1, R4 and R6 instead of 1:1:1. – BrtH Aug 02 '19 at 21:11
  • @BrtH It's all about assumptions. Your simulation assumes the voltage source can produce an unlimited current. In which case I fully agree. – Dmitry Grigoryev Aug 07 '19 at 07:21
Just being in "high voltage water" won't electrocute you, just as birds can happily perch on 10+kV power lines (and linemen can be dropped onto live lines for maintenance work), since there's no path, but as you say, there's always going to be a path to ground somewhere in that water, and so there'll be currents flowing through the water. Since that means that there's potential differences across the water at different points, you'd experience that between your feet, and since the human body is a good conductor, other than the skin, which reduces greatly in resistance when wet, that would allow possibly lethal current to flow through the torso. People can and do get electrocuted standing in salty bilge water on 24V systems on boats, it doesn't take a lot of voltage if the resistance is low enough.
Phil G
  • 5,609
    I'm pretty sure birds are safe because of their low capacitance (from their small size). It ensures very little AC current can flow through them. – forest Apr 08 '19 at 21:15
  • Electrocuted by 24V? Do you have a case reference? – Peter - Reinstate Monica Apr 10 '19 at 09:30
  • @forest They are safe because the potential difference between their feet is minimal and they are not touching any grounded objects. OK, if they had a high capacitance some initial current would flow *into* them upon contact, but nothing "flows through them" unless they touch something else. – Peter - Reinstate Monica Apr 10 '19 at 09:32
    @PeterA.Schneider That's not entirely true for AC current. Many humans have been killed instantly by touching high-voltage AC lines. There are some horrible videos on LiveLeaks showing that, where people catch onto the wires while not grounded, sometimes even while not touching _anything_ but the wire. The AC current is sometimes even high enough to cause burns that instantly expose bone (really). The myth that you can only be electrocuted if you are grounded, even if the voltage is obscenely high, has killed many. – forest Apr 11 '19 at 04:48
    @PeterA.Schneider You can _absolutely_ get electrocuted with only 24V if your skin resistance is low enough (due to injuries or contact with salt water, etc.). Even 12V can be harmful. – forest Apr 11 '19 at 05:40
  • @forest You say there are videos of non-grounded people getting harmed; I looked but didn't find anything. Do you have a reference? It's certainly not true for 50 or 60Hz because there are two very efficient protections: [Protective boots] for up to 20 kV and isolating transformers. So either you are talking higher frequencies (but at high enough frequencies the [health hazards also diminish](https://en.wikipedia.org/wiki/Tesla_coil#Health_hazards); or very high voltage. But with high voltage AC would be as dangerous as DC. – Peter - Reinstate Monica Apr 11 '19 at 06:22
    @PeterA.Schneider I'm not particularly eager to go looking through videos of foolish teenagers getting themselves killed, but I believe the voltage must have been significantly higher than 20 kV given how violent the death appeared. This was also in a 3rd world country from what I remember, so protections were likely to be insufficient. From what I remember, the video was of a teenager trying to catch on to a damaged electric line and his whole body going up in flames. I'm sure you could look at BestGore or LiveLeaks with the search term "electrocution" if you _really_ want to see... – forest Apr 11 '19 at 06:31
  • @forest I did look there; unfortunately such events are relatively common, and I didn't immediately see anything relevant. Anyway, for such high voltages (>10^4) you have arcs anyway, so you don't need to touch anything to have a ground fault emerge. I'm still skeptical about the capcitance thing because I have never heard of it. – Peter - Reinstate Monica Apr 11 '19 at 08:45
Definitely don't try any of these things. This is definitely not intended to imply you should be complacent about any of the dangers of electricity, but there are numerous things that are often extremely wrong in movie handling of electricity, particularly in this type of scene. Often effects are used to simply make the electricity do what the story requires, so a few things:
  • Overcurrent and other fault protection: In most of the world, every circuit has over current protection and many circuits have ground fault or arc fault protection. As manufacturing capability increases, we've been able to add more ways to protect electrical installations and make them safe. In a futuristic scenario with improved technology, there is usually no reason this would have changed. Faults damage equipment, so even in a scenario where disregard for human life is written in, systems would have advanced precautions to limit property damage. At any rate, often the conductor you see creating the danger is actually a cable, with visible wires sticking out of the end, whatever the prop department thought would look cool. In many of these cases, the conductor, as presented, would have shorted between it's own conductors and tripped its overcurrent device or GFCI. In order for the conductor to stay live, something else must go wrong, like it miraculously not shorting out when being pulled loose from what it was connected to, falling, and or jiggling without shorting out on itself or touching something made of metal, or the breaker welding closed(which does occasionally happen).
  • Electricity flows more on paths of less resistance. You could place large copper wire, a wet log and a strip of asphalt side by side, and connect the same voltage at once to the ends of all three. Most of the current would flow through the copper wire, much less would flow through the wet log, and a negligible amount through the asphalt, though there would be current flow in all three. If the conductors on a broken cable have enough voltage to create CGI arcs to nearby fixtures/water/whatever things that are far away, they have enough voltage to arc to its own return conductor or ground, which is sometimes mistakenly portrayed as inches away. For its own return conductor or ground to not be the target of most arcs, a second thing has to go wrong. Those conductors have to be broken somewhere between the arcing cable and the source, somehow without damaging a single high voltage cable more than would allow it to function. Electricity will not tend to travel through a meter of air to establish an arc when a 20mm arc establishes a low impedance return path.
  • Electricity is often much more brutal and much less flashy than in the movies, and movies often portray a greater(or smaller) margin for survival than actually exists. As part of your training in electrical industries, especially in power distribution, there's a good likelihood you'll see a video of someone dying working with or around electricity. It's utterly terrible. Brutal, merciless, and not always quick. The actual speed that electricity can "change" and propagate at is fast enough to need quality examples to make it easy to comprehend. There are situations where high voltage is portrayed in movies as something that great dexterity, strength and skill can just deal with, and inevitably characters are sometimes shown doing something that would have killed or vaporized them. Sometimes with low voltage wires a character is shown killed by something that, as presented, would have a relatively low probability of being lethal. In the latter case I'm comfortable with that as laymen and professionals should treat something with a very good chance of killing them as something that will.
  • Electricity flows in loops. Each molecule, depending on bonding, nuclei, and electron shells, tends to keep roughly a certain amount of electron in each area around it. The electrons themselves are bouncing around, and when they are not held too tightly where they are, they fly freely between nearby molecules, and the limiting factor is that when/as an electron moves out of an area that "needs" an electron, forces will be exerted on other nearby electrons as well as the one flying away to pull them in and fill the gap. Depending on structure of molecule and nuclei, different materials either bind their electrons tightly(insulators) or allow them to flow more freely(conductors). When you cause electrons to flow along a wire, new ones must replace the ones that flow away. The area you are pumping the electrons to will have too many and the area you are pumping them from will not have enough. There is nowhere for the flow to go other than back to where there are too few, as all of the other molecules around have exactly enough. No loop, no current.
  • Water isn't really a good conductor. Dirty water, particularly salty water is. Pure water is not (tap water is not pure). Aside from that, if you put a generator on the shore of an ocean and strung a wire across the surface of the water to a point far out where the tip of the wire was bare, 1 meter underwater, and connected the generator to that wire and a ground rod, the generator would work to pass a current down that wire, into the water, along the earth, through the ground rod, and back to the generator, where the electrons you're pumping out need to be replaced. Because of the high(ish) conductivity of salt water, there wouldn't be high voltages/currents for too high a distance in most directions around the tip of that wire, as the flow of electrons is "attempting" to return on the shortest path possible to its source. voltage will spread out in other directions somewhat as the flowing electrons spread out to travel more freely. This is not to say that the water around the electrode is not dangerous, but to point that movies are often not specifically accurate with where current is flowing.
  • Flashy arcs and sparks - Electricity is invisible. All we can see are the effects on objects as electricity passes through them. Heat, light, motion, the occasional smell. In order to draw attention to them, arcs, sparks and flashes are often brighter than they might be in real life, or of the wrong type (explosive rather than plasma, for example). The resistivity of air is around 2100V/mm, meaning to start an arc through room temperature air, you need 2100V for every mm you want the arc to jump. Once the air starts conducting and becomes a plasma, it conducts quite well, but it takes quite a voltage to start an arc.
K H
  • 4,023
    _"•Electricity follows the path of least resistance"_ Not true. Give it two paths, 1000 and 1001 ohm. Does all current flow in the 1000 ohm path and no current in the 1001 ohm path? – winny Apr 09 '19 at 09:15
    @Winny Good point. I spouted off a safety axiom in my effort to keep things simple =P. Corrected now. Please check the rephrase if you have the time =). – K H Apr 09 '19 at 23:30
You are electrocuted when a current of more than 100 mA flows through you. The wire does not do the electrocuting, it only connects you to a current source.
  1. If there is no current source, there is no current. So go ahead and grab that wire. Nothing will happen. On the other hand, if the wire is connected to a current source, like the 220 VAC power to your clothes dryer, you are likely to die.
  2. There is nothing magic about a "dangling" wire. If the wire is rigidly supported, it will kill you just as dead as if it were dangling.
  3. To determine if the electric field inside water that is conducting can kill you... that requires a 3 dimensional finite element analysis of the voltage distribution within the body of water. If the wire is hot and is touching the water, you best stay out of it. On the other hand, near the edge of the water, where it is very shallow, the current will be minimum. So you might stick your toe in and see if you can feel anything before proceeding further.
  4. You can increase the lethality by adding ions to the water. Salt will do this, or any strong acid or base.
  5. Some utility wires are not wires at all and carry no current. They are fiber optic cables and are harmless. But don't bet on it.
richard1941
  • 632
