I have read somewhere that a TVS is nothing else than a robust Zener diode. My application requires using 300V zener diodes (that may exist but do not pop up so easily), but TVS at 300V are very common and inexpensive. My question is: can TVS diode be used to regulate the voltage in reverse mode like a usual Zener diode would do ?
Asked
Active
Viewed 277 times
1See this thread, maybe it helps https://electronics.stackexchange.com/questions/233600/differences-between-tvs-diode-and-zener-diodes-in-diagrams-and-in-practice – Willy Wonka Apr 05 '19 at 12:23
An ideal one could. In practice, I'd question the precision of the breakdown voltage; it seems unlikely that TVS diodes, which are made to stop fault conditions, would require as precise a breakdown voltage as Zener/avalanche diodes, which are made to be voltage references. – Hearth Apr 05 '19 at 13:29
Google "The XY Problem stack exchange", read that and decide whether you might want to explain why you think you need a 300V zener diode. – K H Apr 06 '19 at 03:42
You can read this article and see why I want 300V zener diode: https://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.885.9903&rep=rep1&type=pdf – MikeTeX Apr 06 '19 at 19:32
@MikeTeX Thank you for sharing a good article. Are you working on free energy machine? – eugene-bright Feb 13 '22 at 11:38
@eugene-bright. Not at all, sorry. – MikeTeX Feb 14 '22 at 08:12
Never mind. But it's good time to have one... – eugene-bright Feb 15 '22 at 09:42
