According to an EE friend, the FCC specifies EMI tolerances (max outputs) for PC components, including cases. However, here it says that there are standards for a number of components but not cases.
1) Am I understanding correctly that there are no requirements for cases?
2) According to the EE in question constructiong a PC case from anything but (mostly) metal will result in excessive EMI radiation for my purposes (audio) leading to stray signals. Furthermore he says that ventilation holes (number, diameter, and position) are calculated based on stray em wavelength. Is this the case?
3) If all of the above are the case, is there perhaps some lining I could apply to non-metallic enclosures to control stray EMI?
Many thanks in advance
Joe
Joe Stavitsky
  • 1,149
  • 26
Correct. The requirement is for the complete product. Be aware that the requirement is not just for your product to pass the test once in a type test, but for every unit in use to meet the requirements.
That's basically correct. It is possible to design a circuit that can pass the requirements with no shielding provided by the case; but doing so requires either a fairly simple product or extreme care (and probably trade-offs in functionality) when designing it. Most digital products you see depend on the shielding provided by their cases to meet the requirements.
It's also correct that the ventilation holes in your case should be designed in part to maintain the shielding properties of your case. Each opening in the case has the potential to act as a slot antenna, which will radiate efficiently at wavelengths above 4x or so the longest dimension of the opening.
Also, although each opening might not radiate efficiently, an array of holes in the case can produce constructive interference, leading to substantial radiation at certain frequencies, which may be what your friend was thinking of when he mentioned the number of holes affecting the radiation.
Yes. You could either build a shielding enclosure around your circuit and then install the whole shield into the externally-visible case, or you could apply a metallic coating to the inside of a plastic or other non-metallic case. For example, Laird Technologies offers Eccoshield ES conductive lacquer coating. I've never priced these materials, but I suspect that they will cost more than simply using a metal case.
One trick with a paint-on coating is that typically you want the shield to be connected to the circuit ground or an external ground by some means, so you'll need to have some kind of reliable contact to the shield.
The Photon
  • 126,425
  • 159
  • 304
  • This is all extremely sad, from a prototyping point of view What would be your suggestion for things to look into given that I want to design ground-up for modular field repair (ie prefab panels, optimally) and do as much of the machining myself as I possibly can? I was originally going to put plastic panels over this http://www.boschrexroth-us.com/country_units/america/united_states/sub_websites/brus_dcl/Products/Aluminum_Structural_Framing/index.jsp but thats no longer in the cards. Could I use single vent holes rather than gratings, for instance? – Joe Stavitsky Oct 08 '12 at 05:26
  • @JoeStavitsky, without knowing how big your system is, what kind of radiators are involved, what kind of i/o you have, what your budget is, what your cosmetic expectations are, it's hard to make any recommendation. That said, given the extrusions you linked, I guess your system is fairly large. You could look, for example, at http://www.hammondmfg.com/racks.htm for some ideas. – The Photon Oct 08 '12 at 16:07
  • Been there, very good product but it looks to be out of budget. I will keep an eye on ebay of course. Thanks again – Joe Stavitsky Oct 08 '12 at 23:59
