I have an old CRT monitor (Phillips CM8833) which I am attempting to repair. When displaying a composite PAL signal, it only shows a black and white image, but it is still able to display RGB signals correctly.
The composite signal is filtered into chrominance and luminance portions, with the chrominance signal sent into a TDA4510 color decoder. The U and V output are fed with the luminance (Y) into a TDA3505 control chip (which can also switch between the composite/YUV and RGB inputs, hence the RGB is unaffected). Here's an overview of the circuit:
I see the indicated signals at test points 9 (input) and 8 (luminance) but not at test point (chrominance), which suggests a fault with the filter circuit between points 9 and 7:
Probing between R529 and R554 shows an AC signal of 150mV peak-to-peak, one-tenth of the amplitude at testing point 9. Measuring between C554 and C556 the AC component is down to less than 30mV peak-to-peak, and after C556 (testing point 7) it's indistinguishable from noise.
I've desoldered and tested all of these components individually, and all the resistors and capacitors appear to be within specification. (I've also replaced the TDA4510, as a precaution.) The inductor, S555, doesn't have a value listed on the circuit diagram or the parts list, but it matches the value of the color bands on its side (red, violet, black, gold, making 27uH).
I've been reading up on the operation of PAL systems, and I think that this monitor is using a bandpass & notch filter to isolate the chrominance and luminance signals. (The CM8833 service manual mentions adjusting S533 to calibrate the "4.43MHz blanking circuit in the luminance circuit", which suggests it's using a notch filter.)
C555 and S555 look to be forming a parallel-tuned bandpass filter, but using \$f= \frac{1}{2\pi \sqrt{LC}}\$ with 12pF and 27uH I get a resonant frequency of 8.84MHz, twice what I'd expect for a chrominance signal.
I'm left with some questions:
- Is my analysis of C555 and S555 correct?
- Are C554 and C556 serving as decoupling capacitors, or do they have some other function?
- What are resistors R529, R553, and R554 doing?
