I am in the process of selecting a microcontroller to interface (~30 signal lines) to an FPGA that operates at 1.8V voltage levels.
I have found NXP's Cortex M0's to operate down to 1.8V which is great, but the bulk of Cortex M3 chips out there have a minimum operating voltage of 2V.
Should I restrict myself to the M0's? Or should I just use level translators? Are there Cortex M3 implementations that have an I/O voltage of 1.8v?
Note that I do have other voltage levels available on the board, but i just need the micro's I/O voltage to be compatible with 1.8V logic.
cksa361
  • 3,814
  • 49
NXP has 74 different Cortex-M0 controllers, so if the M0's performance is good enough (they run at 50 MHz maximum), then you'll probably find a type which has the right features for your application.
If you want more options or need a higher performance you could go for the Cortex-M3 combined with a GTL2000.
The GTL2000 offers you 22 fast channels which you can use unidirectional or bidirectional, and as you can see in the diagram you can interface with several voltage levels with a single device. The GTL2000 can work with levels between 1 V and 5 V on either side. This is a cost-effective solution if you have many lines between the controller and FPGA, but there are also versions with less transceivers if you can do with less. The GTL2010 is a 10-channel version.
stevenvh
  • 145,145
  • 455
  • 667
it depends, read the microcontroller manual and find out what's the voltage level that specified in the manual. Not only the voltage level, for a example TTL means lots of electrical specifications than just 5V.
see : http://infosys.co.kr/e002/e002-s01.html
so guessing that you talking about a TTL microcontroller interface, you need to have at least 2.0 to represent logic level 1.
So the answer is YES. You need a level converter.
Standard Sandun
  • 1,695
  • 38
