I understand how these ultrasonic sensors work on the basic level: They send out ultrasound, which is then reflected by an object and is then sensed by the receiver.
But the receiver and the transmitter are placed side by side. Won't the receiver immediately pick up the signal as it is sent? How does ignore the signal as it is sent, and record it only as it returns after being reflected by the target?
S. Rotos
  • 3,197
    The receiver is 'blanked' until the transmitted pulse is finished typically so the receiver is basically out of circuit until that point. That is for a pulsed system; other techniques for very short range include modulating the signal. – Peter Smith Mar 25 '19 at 16:17
    The signal sent as pulses. These sensors are not good for ultra-short ranges, so the signals received "immediately" are filtered out. – Eugene Sh. Mar 25 '19 at 16:17
  • @Peter Smith Interesting, what kind of modulation is used for short range? – S. Rotos Mar 25 '19 at 16:30
  • The Polaroid onestep autofocus camera used 50KHz sin-bursts, if I recall rightly. Whereas human-body internal-sonograms use 2MHz-5MHz bursts. – analogsystemsrf Mar 25 '19 at 16:51
  • @analogsystemsrf Really? They use acoustic sensors to measure distance? Well, this won't perform well through a window... – Eugene Sh. Mar 25 '19 at 16:56
  • @Eugenesh: Key word here is "used." My family had one of them back in like the late 1970s or early 1980s. I'm not sure you could even get film packs for them today. – JRE Mar 25 '19 at 17:05
  • And, no, it didn't work well through windows. – JRE Mar 25 '19 at 17:05
  • @PeterSmith: That's the answer. Would you like to post it as such? – JRE Mar 25 '19 at 17:06
  • @S.Rotos - the modulation techniques vary but are usually either frequency swept or amplitude swept. That is an enormous area of study, incidentally. – Peter Smith Mar 25 '19 at 18:58
  • I suspect that some systems are capable of handling multiple return signals (from multiple "targets" at differing distances) - and that they can even handle overlapping return signals (by using some form of software correlation). In this situation, the transmitted signal is just one more target at almost zero distance, and can be filtered out of the target list quite easily. Perhaps someone that knows more about this could comment or answer? – Allison Lock Mar 26 '19 at 09:12
In a pulsed system (the most common type), the receiver is blanked during the period of the transmit pulse so it does not respond during that time.
This is the same in pulsed Sonar and Radar and determines the minimum distance that can be resolved.
Peter Smith
  • 21,923
  • 64
There are monostatic and bistatic ultrasonic transceivers.
Monostatic
Monostatic transceivers are single transceivers that do the transmitting and receiving. As long as the transmission stops before the reception starts, you can do measurements. The minimum distance that you can measure is limited in this configuration, but it's smaller and cheaper to implement. Speed of sound is roughly 343m/s. If we assume there is an object 1 meter in front of the sensor, it will take the signal 6 milliseconds to bounce back. That's the window that you're allowed to drive the transceiver and stop it from vibrating at that distance. At 0.1 meters we have 0.6 milliseconds etc. It becomes extremely hard and frankly impossible to drive a proper signal in that timeframe.
If you want to get technical: while transmitting the membrane of the transceiver is being vibrated at a specific frequency. If you'd try to read(receive) anything while it's doing this, you're just going to get a oversaturated signal back. When you stop actively driving the transceiver it will stop ringing in a short time, at which point you can start listening to what it's receiving.
Bistatic
A bistatic transceiver(the one in your picture) uses a separate transmitter and receiver, which means it can receive while transmitting. The minimum distance isn't limited like the monostatic configuration. If you have the space you should go for this configuration. It's easier, better performing and also widely available. The parking sensors on cars use the monostatic configuration for example.
Your question
You're asking why the receiver isn't immediately picking up the signal from the transmitter. While it's true that cheap implementations basically shut the receiver off while transmitting, this is not required. And I'd argue that if you do that sort thing in your design, you should go for a monostatic configuration. Otherwise you're just wasting space and parts.
The directivity of ultrasonic transceivers is fairly precise and won't affect a receiver that's next to it as long as you physically separate the vibrations from each other(A PCB won't effectively transfer kHz frequencies) and don't point it at each other. Most transmitters cap out at ~90 degrees field of view@40kHz(most common) which is enough to keep it from affecting the receiver.
For example, this one has a FoV of 80 degrees with the following graph in the datasheet:
See how it tapers off at the extreme edges?
Tryphon
  • 109
    Sorry, but a lot of your beliefs here are practically mistaken - crosstalk between transducers on a little PC board is a very real problem, remember the transmit pulse is many orders of magnitude stronger than the receive one. Also the kinds of power setups and circuitry in general used on the cheap ones provide another source of crosstalk. Further, the term "bistatic" does not really apply to situations where the transmitter and receiver are effectively co-located, but rather to those where there is substantial spacial separation. – Chris Stratton Mar 25 '19 at 19:19
  • @ChrisStratton I did mention that the cheap boards tend to compensate for cross-talk by simply shutting off the receiver when transmitting. It's an implementation detail that isn't required if you have a proper setup that isolates the transceivers on a mechanical level. Furthermore, the distance between the transducers is relative to the actual distance you're measuring. A few cm is quite a lot when you're only measuring a few meters of distance at the power required to drive the transmitter. – Tryphon Mar 25 '19 at 19:37
    Again, no. Actually look at one of these and you'll see that the distance between the transducers is negligible at the useful ranges. Actually *try* to build a variation which can operate without blanking for the duration of the transmission pulse and transmit transducer ringing and you'll realize that is a lot harder than you *imagine* as well. – Chris Stratton Mar 25 '19 at 19:41
