MPU6050 datasheet says that maximum accelerometer data output is 1Khz, so in theory when measuring time it takes to receive 1000 data samples through I2C, so I should receive all data in no less than 1 second, but somehow i always get sub 0.3 seconds.
Does CPU clock halts when waiting for data incoming from I2C slave?
How to have constant MPU6050 1khz output data rate, and measure it?
#include <wiringPi.h>
#include <wiringPiI2C.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#define Device_Address 0x68 /* i2c-MPU6050*/
#define PWR_MGMT_1 0x6B
#define SMPLRT_DIV 0x19
#define CONFIG 0x1A
#define GYRO_CONFIG 0x1B
#define INT_ENABLE 0x38
#define ACCEL_XOUT_H 0x3B
#define ACCEL_YOUT_H 0x3D
#define ACCEL_ZOUT_H 0x3F
#define GYRO_XOUT_H 0x43
#define GYRO_YOUT_H 0x45
#define GYRO_ZOUT_H 0x47
int fd;
void MPU6050_Init(){
wiringPiI2CWriteReg8 (fd, PWR_MGMT_1, 0x00); /* Disable sleep mode*/
wiringPiI2CWriteReg8 (fd, SMPLRT_DIV, 0x07); /* 8khz/(1+7)=1khz */
wiringPiI2CWriteReg8 (fd, CONFIG, 0x00); /* FSYNC and DLPG_CFG disabled for maximum bandwith*/
wiringPiI2CWriteReg8 (fd, GYRO_CONFIG, 0x00); /* +- 200°/s, and acc by default +-2g's*/
short read_raw_data(int addr){
short high_byte,low_byte,value;
high_byte = wiringPiI2CReadReg8(fd, addr);
low_byte = wiringPiI2CReadReg8(fd, addr+1);
value = (high_byte << 8) | low_byte;
return value;
void passtime(int uSeconds)
// Storing start time
clock_t start_time = clock(); //time in microseconds.
// looping till required time is not achieved
while (clock() < start_time +uSeconds);
int main(){
double time_spent = 0.0;
float Acc_x,Acc_y,Acc_z;
float Gyro_x,Gyro_y,Gyro_z;
float Ax=0, Ay=0, Az=0;
float Gx=0, Gy=0, Gz=0;
fd = wiringPiI2CSetup(Device_Address); /*Initializes I2C with device Address*/
MPU6050_Init(); /* Initializes MPU6050 */
int count =0;
passtime(10000);
clock_t begin = clock();
while(count<1000)
//Maximum output rate of MPU6050 is Accelerometer+Gyroscope = 1khz => 1 data read per milisecond
/*Read raw value of Accelerometer and gyroscope from MPU6050*/
Acc_x = read_raw_data(ACCEL_XOUT_H);
Acc_y = read_raw_data(ACCEL_YOUT_H);
Acc_z = read_raw_data(ACCEL_ZOUT_H);
Gyro_x = read_raw_data(GYRO_XOUT_H);
Gyro_y = read_raw_data(GYRO_YOUT_H);
Gyro_z = read_raw_data(GYRO_ZOUT_H);
/* Divide raw value by sensitivity scale factor for +-2g's, and +-250/s */
Ax = Acc_x/16384.0;
Ay = Acc_y/16384.0;
Az = Acc_z/16384.0;
Gx = Gyro_x/131;
Gy = Gyro_y/131;
Gz = Gyro_z/131;
//printf("\n Gx=%.3f \tGy=%.3f \tGz=%.3f \tAx=%.3f g\tAy=%.3f g\tAz=%.3f g\n",Gx,Gy,Gz,Ax,Ay,Az);
count++;
clock_t end = clock();
time_spent += (double)(end-begin)/CLOCKS_PER_SEC;
printf("Time spent %lf after %d data reads\n",time_spent,count);
getchar();
return 0;
/* OUTPUT:
* Time spent 0.2312s after 1000data reads*/
