I have built a board as shown in the images and the schematic below. I know that according to the datasheet when no current is flowing through the ACS712 it should output something around 2.5V always. However, the sensor is presenting a weird behaviour: When I power the whole board and measure the voltage across the ACS712 output and ground I can see the voltage of 2.5V for a few moments, but then its voltage output drops to something around to 0.3V and keeps oscillating until the maximum of 0.8V.
What could it be? I have already tested with other brand new parts of ACS712 and the same behaviour is occurring.
Things I think it's important to know:
- The logic voltage (Vcc) is always stable. 4.99V ~ 5V
- The whole board is an H-bridge with a current sensor on it.
- When the board is powered (with no load), I can note that the voltage regulator heats, not too much, but the enough to create discomfort after some time.
- The L293DD also heats, but less than the voltage regulator
May it be a hardware fault? Maybe the temperature? Maybe some external interference?
Can anyone help me?
