I'm building a lighting fixture using big led panels.
The LED panel says it requires 7 amps @ 12 volts, but the power supply I have is only rated to 4 amps @12 volts.
What will happen? Will it damage the power supply, or just not light up all the way?
JRE
  • 67,678
  • 179
Jacob Lov
The power supply may be damaged if it does not have over-current protection. The LEDs should not be damaged, but won't light to full brightness, or will not light at all if the power supply shuts down or fails.
Peter Bennett
  • 57,014
  • 127
As the current is insufficient, I think the leds will not light up properly or might not light up at all. I don't think there will be any damage to the power supply.
  • Since we don’t know the design of the supply, it is also possible that it could overheat and set on fire. – HandyHowie Mar 21 '19 at 17:42
