I have a signal (digital) which has output levels of 0V (logic 0) and 3.5V (logic 1).
I would like to know if it is possible to shift it between -2V (logic 0) and 1.5V (logic 1).
I found here on stackexchange and on google various example, but they all assume positive levels (0-5 or 0-3.3) and I don't really understand how to make them work in my case.
Thanks for all the help
EDIT after a couple of questions:
  • I have available easily on board: -2V, 0V, 1.5V, 5V
  • I am sending the signal to a CMOS logic gate
EDIT 2: Just to add a bit more to my question:
if you look at this thread Level shifting a +/- 2.5V signal to 0 - 5V
the first answer provides a very nice circuit to do level shifting.
My problem is that I do not understand how to modify the circuit to fit my needs (see above).
In particular, I am quite puzzled by the supply value of the OpAmp. It looks to me I should use +1.5 and -2, but then I get lost in understanding what is going on.
Cesco
  • 49
The LM358, being a single supply op amp, saturates in the negative direction within a few mVs of the negative supply rail.
You did not mention any more specific requirements for the output signal, i.e. frequency and output impedance, but this is a very simple circuit that could get the job done for low to medium frequencies and with an output impedance determined by R1:
V1-V3 represent your power supplies of +3.5V, +1.5V and -2V w.r.t. GND.
Using a P-channel MOSFET you can switch the +1.5V line to the output. The pull down resistor R1 provides -2V to the output when the MOSFET is off.
Because we need a P-MOSFET here, which turns on when the gate is driven low, an additional inverter is needed. This inverter however can be as simple as another MOSFET and a resistor.
Note that I just picked a random FET to illustrate the circuit. You would need one that already turns on sufficiently at -3.5V.
JimmyB
  • 3,823
