The following is the top level module of a VC707 based Microblaze/PS2 controller.
I have connected a FMC-CE GPIO Daughter Card to the FMC1 Connector on the FPGA and a PMOD-PS2 on the 6 pin GPIO header on the board.
What do I need to do to pass DRC?
MMIO Unit
`include "chu_io_map.svh"
module mmio_sys_sampler_arty_a7
parameter N_SW = 8,
N_LED = 8
(* dont_touch = "true" *) input logic clk,
(* dont_touch = "true" *) input logic reset,
// FPro bus
(* dont_touch = "true" *)input logic mmio_cs,
(* dont_touch = "true" *)input logic mmio_wr,
(* dont_touch = "true" *)input logic mmio_rd,
(* dont_touch = "true" *) input logic [20:0] mmio_addr,
(* dont_touch = "true" *)input logic [31:0] mmio_wr_data,
(* dont_touch = "true" *)output logic [31:0] mmio_rd_data,
// uart
(* dont_touch = "true" *) input logic rx,
(* dont_touch = "true" *)output logic tx,
// ps2
inout tri ps2d,
inout tri ps2c
//declaration
logic [63:0] mem_rd_array;
logic [63:0] mem_wr_array;
logic [63:0] cs_array;
logic [4:0] reg_addr_array [63:0];
logic [31:0] rd_data_array [63:0];
logic [31:0] wr_data_array [63:0];
logic [15:0] adsr_env;
// body
// instantiate mmio controller
chu_mmio_controller ctrl_unit
(.clk(clk),
.reset(reset),
.mmio_cs(mmio_cs),
.mmio_wr(mmio_wr),
.mmio_rd(mmio_rd),
.mmio_addr(mmio_addr),
.mmio_wr_data(mmio_wr_data),
.mmio_rd_data(mmio_rd_data),
// slot interface
.slot_cs_array(cs_array),
.slot_mem_rd_array(mem_rd_array),
.slot_mem_wr_array(mem_wr_array),
.slot_reg_addr_array(reg_addr_array),
.slot_rd_data_array(rd_data_array),
.slot_wr_data_array(wr_data_array)
// slot 1: UART
chu_uart #(.FIFO_DEPTH_BIT(8)) uart_slot1
(.clk(clk),
.reset(reset),
.cs(cs_array[`S1_UART1]),
.read(mem_rd_array[`S1_UART1]),
.write(mem_wr_array[`S1_UART1]),
.addr(reg_addr_array[`S1_UART1]),
.rd_data(rd_data_array[`S1_UART1]),
.wr_data(wr_data_array[`S1_UART1]),
.tx(tx),
.rx(rx)
// slot 11: ps2
chu_ps2_core #(.W_SIZE(6)) ps2_slot11
(.clk(clk),
.reset(reset),
.cs(cs_array[`S11_PS2]),
.read(mem_rd_array[`S11_PS2]),
.write(mem_wr_array[`S11_PS2]),
.addr(reg_addr_array[`S11_PS2]),
.rd_data(rd_data_array[`S11_PS2]),
.wr_data(wr_data_array[`S11_PS2]),
.ps2d(ps2d),
.ps2c(ps2c)
// assign 0's to all unused slot rd_data signals
generate
genvar i;
for (i=14; i<64; i=i+1) begin
assign rd_data_array[i] = 32'h0;
end
endgenerate
endmodule
UART
// Reg map (each port uses 4 address space)
// * 0: read data and status
// * 1: write baud rate
// * 2: write data
// * 3: dummy write to remove data from head of rx FIFO
module chu_uart
#(parameter FIFO_DEPTH_BIT = 8) // # addr bits of FIFO
(* dont_touch = "true" *)input logic reset,
// slot interface
(* dont_touch = "true" *) input logic cs,
(* dont_touch = "true" *) input logic read,
(* dont_touch = "true" *)input logic write,
(* dont_touch = "true" *) input logic [4:0] addr,
(* dont_touch = "true" *)input logic [31:0] wr_data,
(* dont_touch = "true" *) output [31:0] rd_data,
(* dont_touch = "true" *) output logic tx,
// signal declaration
logic wr_uart, rd_uart, wr_dvsr ;
logic tx_full, rx_empty;
logic [10:0] dvsr_reg;
logic [7:0] r_data;
logic ctrl_reg;
// body
// instantiate uart
uart #(.DBIT(8), .SB_TICK(16), .FIFO_W(FIFO_DEPTH_BIT)) uart_unit
(.clk(clk), .reset(reset), .rd_uart(rd_uart), .wr_uart(wr_uart), .rx(rx), .dvsr(dvsr_reg), .w_data(wr_data[7:0]), .tx_full(tx_full), .rx_empty(rx_empty), .tx(tx), .r_data(rd_data[7:0]) );
// dvsr register
always_ff @(posedge clk, posedge reset)
if (reset)
dvsr_reg <= 0;
else
if (wr_dvsr)
dvsr_reg <= wr_data[10:0];
// decoding logic
assign wr_dvsr = (write && cs && (addr[1:0]==2'b01));
assign wr_uart = (write && cs && (addr[1:0]==2'b10));
assign rd_uart = (write && cs && (addr[1:0]==2'b11));
// slot read interface
assign rd_data = {22'h000000, tx_full, rx_empty, r_data};
endmodule
UART UNIT
// * 2: write data
module chu_uart
logic [7:0] r_data;
logic ctrl_reg;
// dvsr register
if (reset)
dvsr_reg <= 0;
else
if (wr_dvsr)
// decoding logic
endmodule
BAUD Unit
// baud rate generater (divisor)
// divided by (dvsr+1)
// Listing 12.1
module baud_gen
(* dont_touch = "true" *)input logic clk, reset,
(* dont_touch = "true" *)input logic [10:0] dvsr,
(* dont_touch = "true" *)output logic tick
// declaration
logic [10:0] r_reg;
logic [10:0] r_next;
// body
// register
begin
if (reset)
r_reg <= 0;
else
r_reg <= r_next;
end
// next-state logic
assign r_next = (r_reg==dvsr) ? 0 : r_reg + 1;
// output logic
assign tick = (r_reg==1);
endmodule
UART RX
module uart_rx
parameter DBIT = 8, // # data bits
SB_TICK = 16 // # ticks for stop bits
(* dont_touch = "true" *) input logic rx, s_tick,
(* dont_touch = "true" *)output logic rx_done_tick,
(* dont_touch = "true" *)output logic [7:0] dout
// fsm state type
typedef enum {idle, start, data, stop} state_type;
state_type state_reg, state_next;
logic [3:0] s_reg, s_next;
logic [2:0] n_reg, n_next;
logic [7:0] b_reg, b_next;
// body
// FSMD state & data registers
begin
if (reset) begin
state_reg <= idle;
s_reg <= 0;
n_reg <= 0;
b_reg <= 0;
end
else begin
state_reg <= state_next;
s_reg <= s_next;
n_reg <= n_next;
b_reg <= b_next;
end
end
// FSMD next-state logic
always_comb
begin
state_next = state_reg;
rx_done_tick = 1'b0;
s_next = s_reg;
n_next = n_reg;
b_next = b_reg;
case (state_reg)
idle:
if (~rx) begin
state_next = start;
s_next = 0;
end
start:
if (s_tick)
if (s_reg==7) begin
state_next = data;
s_next = 0;
n_next = 0;
end
else
s_next = s_reg + 1;
data:
if (s_tick)
if (s_reg==15) begin
s_next = 0;
b_next = {rx, b_reg[7:1]};
if (n_reg==(DBIT-1))
state_next = stop ;
else
n_next = n_reg + 1;
end
else
s_next = s_reg + 1;
stop:
if (s_tick)
if (s_reg==(SB_TICK-1)) begin
state_next = idle;
rx_done_tick =1'b1;
end
else
s_next = s_reg + 1;
endcase
end
// output
assign dout = b_reg;
endmodule
UART Tx
module uart_tx
SB_TICK = 16 // # 16 ticks for 1 stop bit
(* dont_touch = "true" *)input logic tx_start, s_tick,
(* dont_touch = "true" *)input logic [7:0] din,
(* dont_touch = "true" *)output logic tx_done_tick,
// fsm state type
logic tx_reg, tx_next;
// body
begin
if (reset) begin
state_reg <= idle;
s_reg <= 0;
n_reg <= 0;
b_reg <= 0;
tx_reg <= 1'b1;
end
else begin
s_reg <= s_next;
n_reg <= n_next;
b_reg <= b_next;
tx_reg <= tx_next;
end
end
// FSMD next-state logic & functional units
always_comb
begin
tx_done_tick = 1'b0;
s_next = s_reg;
n_next = n_reg;
b_next = b_reg;
tx_next = tx_reg ;
case (state_reg)
idle: begin
tx_next = 1'b1;
if (tx_start) begin
state_next = start;
s_next = 0;
b_next = din;
end
end
start: begin
tx_next = 1'b0;
if (s_tick)
state_next = data;
s_next = 0;
n_next = 0;
end
else
s_next = s_reg + 1;
end
data: begin
tx_next = b_reg[0];
if (s_tick)
s_next = 0;
b_next = b_reg >> 1;
state_next = stop ;
else
n_next = n_reg + 1;
end
else
s_next = s_reg + 1;
end
stop: begin
tx_next = 1'b1;
if (s_tick)
state_next = idle;
tx_done_tick = 1'b1;
end
else
s_next = s_reg + 1;
end
endcase
end
// output
assign tx = tx_reg;
endmodule
FIFO
module fifo
parameter DATA_WIDTH=8, // number of bits in a word
ADDR_WIDTH=4 // number of address bits
(* dont_touch = "true" *) input logic clk, reset,
(* dont_touch = "true" *)input logic rd, wr,
(* dont_touch = "true" *)input logic [DATA_WIDTH-1:0] w_data,
(* dont_touch = "true" *)output logic empty, full,
(* dont_touch = "true" *)output logic [DATA_WIDTH-1:0] r_data
//signal declaration
logic [ADDR_WIDTH-1:0] w_addr, r_addr;
logic wr_en, full_tmp;
// body
// write enabled only when FIFO is not full
assign wr_en = wr & ~full_tmp;
assign full = full_tmp;
// instantiate fifo control unit
fifo_ctrl #(.ADDR_WIDTH(ADDR_WIDTH)) c_unit
(.clk(clk), .reset(reset), .rd(rd), .wr(wr), .empty(empty), .full(full_tmp), .w_addr(w_addr), .r_addr(r_addr));
// instantiate register file
reg_file
#(.DATA_WIDTH(DATA_WIDTH), .ADDR_WIDTH(ADDR_WIDTH)) f_unit (.clk(clk), .wr_en(wr_en), .w_addr(w_addr), .r_addr(r_addr), .w_data(w_data), .r_data(r_data));
endmodule
Fifo Ctrl
module fifo_ctrl
parameter ADDR_WIDTH=4 // number of address bits
(* dont_touch = "true" *) output logic empty, full,
(* dont_touch = "true" *)output logic [ADDR_WIDTH-1:0] w_addr,
(* dont_touch = "true" *)output logic [ADDR_WIDTH-1:0] r_addr
logic [ADDR_WIDTH-1:0] w_ptr_logic, w_ptr_next, w_ptr_succ;
logic [ADDR_WIDTH-1:0] r_ptr_logic, r_ptr_next, r_ptr_succ;
logic full_logic, empty_logic, full_next, empty_next;
// body
// fifo control logic
begin
if (reset)
begin
w_ptr_logic <= 0;
r_ptr_logic <= 0;
full_logic <= 1'b0;
empty_logic <= 1'b1;
end
else
begin
w_ptr_logic <= w_ptr_next;
r_ptr_logic <= r_ptr_next;
full_logic <= full_next;
empty_logic <= empty_next;
end
end
// next-state logic for read and write pointers
always_comb
begin
// successive pointer values
w_ptr_succ = w_ptr_logic + 1;
r_ptr_succ = r_ptr_logic + 1;
// default: keep old values
w_ptr_next = w_ptr_logic;
r_ptr_next = r_ptr_logic;
full_next = full_logic;
empty_next = empty_logic;
unique case ({wr, rd})
2'b01: // read
if (~empty_logic) // not empty
begin
r_ptr_next = r_ptr_succ;
full_next = 1'b0;
if (r_ptr_succ==w_ptr_logic)
empty_next = 1'b1;
end
2'b10: // write
if (~full_logic) // not full
begin
w_ptr_next = w_ptr_succ;
empty_next = 1'b0;
if (w_ptr_succ==r_ptr_logic)
full_next = 1'b1;
end
2'b11: // write and read
begin
end
default: ; // 2'b00; null statement; no op
endcase
end
// output
assign w_addr = w_ptr_logic;
assign r_addr = r_ptr_logic;
assign full = full_logic;
assign empty = empty_logic;
endmodule
Reg File
// Listing 7.2
module reg_file
parameter DATA_WIDTH = 8, // number of bits
ADDR_WIDTH = 2 // number of address bits
(* dont_touch = "true" *)input logic wr_en,
(* dont_touch = "true" *)input logic [ADDR_WIDTH-1:0] w_addr, r_addr,
logic [DATA_WIDTH-1:0] array_reg [0:2**ADDR_WIDTH-1];
// body
// write operation
always_ff @(posedge clk)
begin
if (wr_en)
array_reg[w_addr] <= w_data;
end
// read operation
assign r_data = array_reg[r_addr];
endmodule
PS2 Core
(* keep_hierarchy = "yes" *)
module chu_ps2_core
#(parameter W_SIZE = 6) // # address bits in FIFO buffer
// slot interface
(* dont_touch = "true" *)input logic cs,
(* dont_touch = "true" *)input logic read,
(* dont_touch = "true" *)input logic [4:0] addr,
(* dont_touch = "true" *)output logic [31:0] rd_data,
// external ports
inout tri ps2d, ps2c
// declaration
logic [7:0] ps2_rx_data;
logic rd_fifo, ps2_rx_buf_empty;
logic wr_ps2, ps2_tx_idle;
// body
// instantiate PS2 controller
ps2_top #(.W_SIZE(W_SIZE)) ps2_unit
(.clk(clk), .reset(reset), .wr_ps2(wr_ps2), .rd_ps2_packet(rd_fifo), .ps2_tx_data(wr_data[7:0]), .ps2_rx_data(ps2_rx_data), .ps2_tx_idle(ps2_tx_idle), .ps2_rx_buf_empty(ps2_rx_buf_empty), .ps2d(ps2d), .ps2c(ps2c));
// decoding and read multiplexing
// remove an item from FIFO
assign rd_fifo = cs & read & (addr[1:0]==2'b11);
// write data to PS2 transmitting subsystem
assign wr_ps2 = cs & write & (addr[1:0]==2'b10);
// read data multiplexing
assign rd_data = {22'b0, ps2_tx_idle, ps2_rx_buf_empty, ps2_rx_data};
endmodule
PS2 Top
module ps2_top
(* dont_touch = "true" *)input logic wr_ps2, rd_ps2_packet,
(* dont_touch = "true" *)input logic [7:0] ps2_tx_data,
(* dont_touch = "true" *)output logic [7:0] ps2_rx_data,
(* dont_touch = "true" *)output logic ps2_tx_idle, ps2_rx_buf_empty,
// declaration
logic rx_idle, tx_idle, rx_done_tick;
logic [7:0] rx_data;
// body
// instantiate ps2 transmitter
ps2tx ps2_tx_unit
(.clk(clk), .reset(reset), .wr_ps2(wr_ps2), .rx_idle(rx_idle), .din(ps2_tx_data), .tx_idle(tx_idle), .tx_done_tick(), .ps2d(ps2d), .ps2c(ps2c));
// instantiate ps2 receiver
ps2rx ps2_rx_unit
(.clk(clk), .reset(reset), .ps2d(ps2d), .ps2c(ps2c), .rx_en(tx_idle), .rx_idle(rx_idle), .rx_done_tick(rx_done_tick), .dout(rx_data));
// instantiate FIFO buffer
fifo #(.DATA_WIDTH(8), .ADDR_WIDTH(W_SIZE)) fifo_unit
(.clk(clk), .reset(reset), .rd(rd_ps2_packet),
.wr(rx_done_tick), .w_data(rx_data), .empty(ps2_rx_buf_empty),
.full(), .r_data(ps2_rx_data));
//output
assign ps2_tx_idle = tx_idle;
endmodule
PS2 Tx
module ps2tx
(* dont_touch = "true" *)input logic wr_ps2, rx_idle,
(* dont_touch = "true" *)output logic tx_idle, tx_done_tick,
// fsm state type
typedef enum {idle, waitr, rts, start, data, stop} state_type;
// declaration
logic [7:0] filter_reg;
logic [7:0] filter_next;
logic f_ps2c_reg;
logic f_ps2c_next;
logic [3:0] n_reg, n_next;
logic [8:0] b_reg, b_next;
logic [12:0] c_reg, c_next;
logic par, fall_edge;
logic ps2c_out, ps2d_out;
logic tri_c, tri_d;
// body
// filter and falling-edge tick generation for ps2c
begin
if (reset)
begin
filter_reg <= 0;
f_ps2c_reg <= 0;
end
else
begin
filter_reg <= filter_next;
f_ps2c_reg <= f_ps2c_next;
end
end
assign filter_next = {ps2c, filter_reg[7:1]};
assign f_ps2c_next = (filter_reg==8'b11111111) ? 1'b1 :
(filter_reg==8'b00000000) ? 1'b0 :
f_ps2c_reg;
assign fall_edge = f_ps2c_reg & ~f_ps2c_next;
// FSMD
// state & data registers
begin
if (reset) begin
state_reg <= idle;
c_reg <= 0;
n_reg <= 0;
b_reg <= 0;
end
else begin
c_reg <= c_next;
n_reg <= n_next;
b_reg <= b_next;
end
end
// odd parity bit
assign par = ~(^din);
// next-state logic
always_comb
begin
c_next = c_reg;
n_next = n_reg;
b_next = b_reg;
ps2c_out = 1'b1;
ps2d_out = 1'b1;
tri_c = 1'b0;
tri_d = 1'b0;
tx_idle = 1'b0;
case (state_reg)
idle: begin
tx_idle = 1'b1;
if (wr_ps2) begin
b_next = {par, din};
c_next = 13'h1fff; // 2^13-1
state_next = waitr;
end
end
waitr:
if (rx_idle)
state_next = rts;
rts: begin // request to send
ps2c_out = 1'b0;
tri_c = 1'b1;
c_next = c_reg - 1;
if (c_reg==0)
state_next = start;
end
start: begin // assert start bit
ps2d_out = 1'b0;
tri_d = 1'b1;
if (fall_edge)
begin n_next = 4'h8;
state_next = data;
end
end
data: begin // 8 data + 1 parity
ps2d_out = b_reg[0];
tri_d = 1'b1;
if (fall_edge) begin
b_next = {1'b0, b_reg[8:1]};
if (n_reg == 0)
state_next = stop;
else
n_next = n_reg - 1;
end
end
default: // assume floating high for ps2d
state_next = idle;
end
endcase
end
// tristate buffers
assign ps2c = (tri_c) ? ps2c_out : 1'bz;
assign ps2d = (tri_d) ? ps2d_out : 1'bz;
endmodule
PS2 Rx
module ps2rx
(* dont_touch = "true" *)input logic clk, reset, rx_en,
inout tri ps2d, ps2c,
(* dont_touch = "true" *)output logic rx_idle, rx_done_tick,
// fsm state type
typedef enum {idle, dps, load} state_type;
// declaration
logic f_ps2c_reg;
logic f_ps2c_next;
logic [10:0] b_reg, b_next;
logic fall_edge;
// body
begin
if (reset) begin
filter_reg <= 0;
f_ps2c_reg <= 0;
end
else begin
end
end
f_ps2c_reg;
// FSMD
begin
if (reset) begin
state_reg <= idle;
n_reg <= 0;
b_reg <= 0;
end
else begin
n_reg <= n_next;
b_reg <= b_next;
end
end
// next-state logic
always_comb
begin
rx_idle = 1'b0;
n_next = n_reg;
b_next = b_reg;
case (state_reg)
idle: begin
rx_idle = 1'b1;
if (fall_edge & rx_en) begin
// shift in start bit
b_next = {ps2d, b_reg[10:1]};
n_next = 4'b1001;
state_next = dps;
end
end
dps: // 8 data + 1 parity + 1 stop
if (n_reg==0)
state_next = load;
else
n_next = n_reg - 1;
end
default: begin // 1 extra clock to complete last shift
state_next = idle;
rx_done_tick = 1'b1;
end
endcase
end
// output
assign dout = b_reg[8:1]; // data bits
endmodule
