Before I begin, I understand this is a very broad and open ended question, please be patient with me. I am a complete newbie to this. After looking around I found various ways of interacting withe the Kinect sensor. ROS, OpenCV, Processing,Matlab....
But they all seem to need a PC in between. Is there a way to transfer data to a microcontroller like Arduino directly and processing the data ( say depth image like a matrix) without a PC?
I would assume there are some C frameworks that would be available for this.
Ender Wiggins
  • 565
Even if you could get the data into an 8-bit microcontroller like an Arduino, it would be completely inadequate to process it. According to Wikipedia, the depth information streaming out of the Kinect is 640x480, 11-bits of resolution. That's about 600 kB of raw data for each frame, and the frame rate is 30 Hz. So, we need to crank through about 18 MB of data each second. This isn't too big of a challenge for a PC, but it's of the league of something like an Arduino.
Instead, you may have better luck using something like a Raspberry Pi. It has a 32-bit ARM microprocessor running at 700 MHz, 256 MB of RAM, and a GPU. It's basically a PC from 8 years ago on a single board.
Theran
  • 3,432
  • Yeah, Arduino will not be the tool for it. Is there any Framework or Library you know of that would let Kinect talk directly to a ARM processor? Edit: ROS on Raspberry Pi might do the job. – Ender Wiggins Oct 02 '12 at 05:13
