1) Is there a more reliable solution than this?
A part like this could become a problem with a Single Event Upset (SEU), it isn't rad-hard (resistant to radiation). If the SEU causes a problem in the circuitry of the TPS2553, then it could cause power issues for your system.
It really depends on the system and how this is connected as a whole if there is something upstream that can shut the power off (which there probably is because you have a battery and it needs a DC to DC converter).
With latch ups and satellite design it's beneficial to have:
- A system that can detect latch ups (over current) and shut down that IC. This means monitoring the current from the battery and solar cells (if you have that in your mass/volume/power budgets). A watchdog timer (external to the microprocessor) is usually employed that needs to get updated from the processor, if it doesn't get updated, then it switches everything off and resets the system power (and the TPS2553). The main thing is preventing the battery from draining to a critically low voltage, if you get the voltage too low, the battery dies (with most chemistries) and the mission is only working in the sun or dead.
- Radation hardened parts, if you really want a robust system, then for the power circuitry use rad hard parts which are increasing in availability (and also are more expensive). Generally pico and nano sats use commercial parts and deal with the fact that they could latch up more often since the mission budgets are lower.
- Use a flash based FPGA or anti fuse for mission critical circuitry
In contrast, the configuration of antifuse and flash-based FPGAs is
immune to SEUs because of their non-volatile structure. Figure 4 shows
the typical flash structure with a floating gate located between a
control gate and the metal-oxide semiconductor field-effect transistor
(MOSFET) structure below, encased in good dialectic. The bit value is
stored as a charge on the floating gate. A charged gate represents a
zero value for NOR flash cells.
Source: http://archive.cotsjournalonline.com/articles/view/102279
Interestingly enough, TI has a recent write up on latch ups and how they are prevented in IC's. It is not known if the TPS2553 has been built and tested to the JEDEC JESD78 standard for latch ups. (and good luck finding out, over the years TI has been poor at communicating with engineers, so I only use them if I absolutely have to). But since 2010 TI has some designs conform to this standard, and mitigating latch ups. Below shows a design that is more immune to latch ups with guardlines
2) Do these depletion mode p-ch devices have particularly high or low
resistance to cosmic radiation?
The problem is mostly related to having pairs of transistors (which the TPS2553 has many):
Latch-Up is a condition where a low impedance path is created between
a supply pin and ground. This condition is caused by a trigger
(current injection or overvoltage), but once activated, the low
impedance path remains even after the trigger is no longer present.
This low impedance path may cause system upset or catastrophic damage
due to excessive current levels.
The Latch-Up condition typically requires a power cycle to eliminate
the low impedance path. CMOS and BiCMOS circuits use NMOS and PMOS
transistors to create the circuit functions. In the design of the CMOS
integrated circuit, the proximity of the PN junctions that form the
NMOS and PMOS transistors create inherent parasitic transistors and
diodes. These parasitic structures create PNPN Thyristors, also called
silicon-controlled rectifiers (SCRs). Excursions (overshoots and
undershoots) outside the normal operating voltage and current levels
can trigger PNPN Thyristors and may cause Latch-Up. Latch-Up is not a
risk if the voltage and current levels applied to the device adhere to
the absolute maximum ratings.
Source: Latch ups SCAA124 TI app note
So it would be more concerning with the driving circuitry of the TPS2553 and having something latch up there and either not being able to control it, or having it self destruct from overcurrent (For example the TPS2553 has an error amplifier (op amp) and many other places which has an output stage that has two transistors in series from VCC to ground. If both of these turn on then you have a short essentially, if the TPS is the thing that is suppoesed to be monitoring current then you have a problem. I would probably go with a circuit that is not integrated with a single high side switch for the load with a pull up and a watchdog circuit on it for resets.
EDIT
1) Is there a more reliable solution than the MOSFET Current limiter
shown above?
A single switch with a watchdog would be better. Odds are the system being designed doesn't have power to waste. Putting a resistor in series with one of the largest loads in the system is not a good idea. This paper has information on the power systems for a nanosat, it would be a good idea to use (or even contact the authors) for information on how they designed their power systems
Source: Nanosatellites in LEO and beyond: Advanced Radiation protection techniques for COTS-based spacecraft
This is unknown, but it doesn't matter what the device is, it will most likely latch up. The way to design spacecraft power systems (or any electronic system) is to plan on the device being fully off or fully on from radiation and then allowing the system to clear the fault (by power cycling). No devices is resistant to latch ups completely but some more than others.
Device resistance is determined by many factors including the materials and construction. The only way one really knows is if the device has been designed and tested against radiation. If you want radiation tolerance, then buy rad hard parts like these MOSFETS. But you still have to plan for latchups due to SEU's. There are some very very high energy cosmic rays out there, and they can ionize anything.
