This is a project I imported from Eagle (not so bad by the way). I resolved all schematic compilation errors. But now I am facing some small issues in the PCB part:
On the properties panel when I select any component, footprint is grayed. See picture. Not a big issue because I can still update my footprints by the menu option (all, or one by one).
Do you know why all my components seem locked? Could I revert this to a "normal" situation where footprint name and library could be modified? This way I could push to schematics modification of footprint done in PCB.
I tried to "update all component footprint" - did nothing.
This is Altium Designer 18.1.8
grayed footprint propreties
EDIT:
Ok, new components that I added since the conversion seems to work as usual. But old one are still locked.
JYelton
  • 32,302
  • 134
  • 249
Dony
  • 116
  • You've neglected to ask a question. – K H Feb 28 '19 at 08:18
  • hum. Good point. So there it is : I never been facing of this. Do you know why all my component seems looked ? and could I revert this to a "normal" situation where Footprint name and library could be modified. This way I could push to schematics modification of footprint done in PCB – Dony Feb 28 '19 at 08:33
  • Click "edit" at the bottom of your question to edit and improve it. Do this every time you add additional information, rather than leaving it in the comments. – K H Feb 28 '19 at 08:35
  • Have you tried unlocking primitives? (Looking at the padlock icon shown in image.) – JYelton Feb 28 '19 at 18:13
  • Hi, yes but did nothing. Thanks – Dony Mar 01 '19 at 07:10
It seems that it is grayed because it is an IntLib as integrated library (locked) and not PCBlib as usually used.
Dony
  • 116
