I am designing a system focused on the uC ATmega328p and I am feeding it directly with a 3.7V LiPo battery. I also have a 3.3V LDO feeding several sensors in the system.
My question is the next, If I want to read the battery voltage [full charge = 4V, discharged = 3V (approx.)] How should I configure the Vcc, AVcc and AREF pins of ATmega in order to achieve that result?
At the moment I feed the ATmega328p (with internal crystal 8MHz) to the battery voltage and I was thinking of connecting Vcc with AVCC and with the 3.3V that the LDO gives me to connect them to AREF and put the voltage of the battery with a voltage divider to an analog arduino input.
What do you think? Any better solution?
PS: I would not like to add any extra components to the system.
Thank you.
Wave Wolf
    Possible duplicate of [How to read high voltages on microcontroller?](https://electronics.stackexchange.com/questions/42710/how-to-read-high-voltages-on-microcontroller) – MCG Feb 20 '19 at 10:36
  • You're not the first to want this, many have done the same already. Some have described how they did this on some website. You should search for "Arduino battery monitor" and you will find plenty of examples. No need to ask here for the same now is there? – Bimpelrekkie Feb 20 '19 at 10:40
  • Yes, you can do that. Or, you can use the internal 1.1V reference. The internal reference will be more stable. You can measure it with high precision for the chip (with a multimeter) and put that in software. 1.1V is nominal, it will vary from chip to chip. The actual value can be stored in eeprom, if producing in large numbers. – Indraneel Feb 20 '19 at 10:50
  • Thanks for the reply Bimpelrekkie, but I'm not using an arduino or 5V as power. @Indraneel with respect to using internal 1.1V, it is necessary to feed Aref with 1.1V but I have no way of doing it (I think). – Wave Wolf Feb 20 '19 at 11:13
  • @WaveWolf it is an **INTERNAL** reference. You do not have to supply anything. It is generated by the uC. Look it up. And just to clarify, make sure you do NOT supply anything to aref when using the internal reference, or it might damage the aref or the reference. It's all there in the datasheet. – Indraneel Feb 20 '19 at 11:59
  • @WaveWolf also, it does not matter if you are using an arduino or not. The arduino is using the atmega328p. searching with the arduino keyword will get you much more help than simply searching with atmega328. (actually atmega8 / atmega88 gets maximum results) – Indraneel Feb 20 '19 at 12:09
  • @MCG given that the questioner is directly powering the ATmega with the battery, and that it can tolerate more than 5V which is above the maximum voltage of the battery, this question is different from that one and is very specific about how to configure the ADC references and supplies. The OP explicitly uses the linked solution and is asking for other possibilities for this specific case. – Edgar Brown Feb 22 '19 at 19:44
You can use the internal 1.1V bandgap reference to indirectly measure the voltage on the Vcc pin. This 1.1V reference is built into the chip and can be connected to the ADC by setting the MUX registers correctly.
Full details here...
https://wp.josh.com/2014/11/06/battery-fuel-guage-with-zero-parts-and-zero-pins-on-avr/
bigjosh
  • 9,888
    Technically you are actually measuring the reference voltage using an unknown voltage as your reference and back-calculating from there. You should probably add that detail to your answer. – Edgar Brown Feb 23 '19 at 05:02
    @EdgarBrown Answer updated to read "indirectly measure". Thanks! – bigjosh Feb 23 '19 at 22:55
Finally I decided to feed Aref with a stable voltage of 3.3V (LDO) used for a sensor in the system. The option of 1.1V I like but for "requirements" of design and components I will use 3.3V and a voltage divider at the output of A0 with the battery voltage. I just need to know when it's running out, I don't need something precise. Thank you all.
Wave Wolf
  • Note: If the dropout voltage of the LDO + 3.3V (ie. minimum input voltage for regulation) is higher than the desired cutoff voltage then you will not be able to detect it, because the reference voltage will drop first - making the measurement higher than expected. So you will need a _true_ LDO with dropout voltage < 0.3V (to detect 'low battery' between 3.6-3.7V), not eg. 1117 types which may drop up to 1V. – Bruce Abbott Feb 23 '19 at 23:21
  • Your plan here is substantially inferior to using the bandgap, and your "requirement of design and components" makes no sense since the bandgap approach doesn't require any components at all. – Chris Stratton Feb 24 '19 at 07:34
  • I'm using a real "LDO", I have no problem :). Chris Stratton, you right. I didn't watch the bandgap link, it's my fault. Thank you again! ;) – Wave Wolf Feb 26 '19 at 00:41
