The question was asked before and is not active anymore, but I am not at all satisfied with the answer:
What's so great about PPC? There's gotta be something
According to David Kessner's answer, there were once reasons for PowerPC, but there are not any today.
While this may be true for desktop computers, it cannot be true for embedded systems. All three major gaming consoles use a PowerPC (Wii, Xbox 360, PS3). Microsoft, focusing completely on Intel at that time, even switched for their new Xbox from Intel to PowerPC in 2005.
Network devices feature in many cases PPC, many automotive microcontrollers do as well and there are still new PPC product developments (e.g. by Freescale). PowerPC's can in addition be found in the storage system, the medical, or industrial automation domains.
Backward compatibility (support of legacy software) is one driver, of course. But there have to be more.
Is it the high scalability and application programming interface compatibility within the PowerPC family, from small microcontrollers to processors for high performance computing?
The robustness of the design and experience with certification of functional safety?
Support of high temperature ranges, especially fan-less designs for high temperatures?
DancingJeff
  • 113
To get the price down to where the gaming consoles require, they all needed custom chips that included a CPU (or three). Of course Microsoft switched from an Intel CPU to a PowerPC, because there was/is no way that Intel will allow their CPU in a custom chip-- especially if it wasn't Intel that was fabbing the chip.
At the time the XBox 360 was created, the PowerPC was the fastest and most reasonable CPU to use. This is no longer the case, where ARM has beat it out. I predict that ARM will be the CPU of choice for the new round of gaming consoles that should be out in the next year or two.
While there are new PPC devices, there are also new 8051 and Coldfire devices. So this, by itself, is not a good indication of how "current" the PPC is. New ARM devices outnumber new PPC devices by maybe 50 to 1.
Now to directly address your questions:
The PPC does not currently offer any scalability advantages. The ARM is actually easier in this department since that CPU was designed with multi-core processing in mind.
The PPC does not offer any API compatibility that ARM or other CPU's do not also offer. Modern software is written completely in a high level language, and so the CPU architecture does not play into API compatibility. Almost nothing is written in assembly language these days, especially on high performance 32/64 bit CPU's.
It is unclear on what you mean by this. For most embedded applications that do not require life-safety, military, or aerospace levels of reliability, the PPC offers no advantage today. ARM's have been proven out just as much, or even more, than PPC. For life-safety, military, or aerospace then there might be an advantage but those markets tend to lag the rest of the world by several generations anyway.
The ARM is a much lower power architecture, which is why ARM is used in mobile devices while PPC is not. Lower power = lower heat = much easier to handle high temperature ranges. Advantage ARM.
Why does there have to be more? I'm positive that this is why 90% of current PPC designs are still using PPC. The other 10% is because some people are just stuck in their ways. There are many examples of old architectures that continue to be used for no good reason. You can still fine Z80 and 6502's being put into new designs, and nobody is calling those good or currently popular.
The reason for the PPC popularity is that it was the right CPU at the right time in the market. Before that it was the MIPS CPU's. Now it's ARM. You still see PPC used because some things just take a long time to die out. There are still MIPS designs out there too.
@NichHalden was also completely correct on this subject.
  • Thank you very much, David, for expanding your position and answering my assumptions. – DancingJeff Sep 25 '12 at 17:40
  • How about the enterprise grade Power series from IBM? In my opinion ARM doesn't even come close to IBM's Power7 when it comes to sheer processing power in high end applications. – jippie Sep 25 '12 at 19:28
  • Wii actually has an ARM security co-processor referred to by hackers as Starlet. IOS (no relation to Apple) runs on Starlet and controls access to a lot of peripherals, but Broadway (the PPC) is where all the interesting numbers get crunched. – ajs410 Sep 26 '12 at 16:31
    I am very sure this is wrong on the first point "no way that Intel will allow their CPU in a custom chip". The original Xbox had a custom Intel chip, and I am sure Intel would have been more than happy to make the next one too, they just were not as price competitive (read as desperate) for the speed required. There is no evidence the Xbox PowerPC decision was based on performance, Intel had much better performing chips, just not for the current and future price points – TFD Sep 27 '12 at 09:38
  • ARM is low power, not ultimate speed, it would have to be many cores, and that is not always ideal for game programming. I suspect the chosen CPU will have these features: price, un-hackable secure code path with support chips, price, GPU integration, price, and possibly price? – TFD Sep 27 '12 at 09:52
  • According to [cnet](http://news.cnet.com/8301-11386_3-57491281-76/slow-but-rugged-curiositys-computer-was-built-for-mars/) a platform around a PowerPC RAD750 microprocessor was chosen for the Mars Rover because it can withstand temperature extremes and massive doses of space radiation. – DancingJeff Sep 28 '12 at 12:02
    @DancingJeff No, that was a specific PowerPC build made to be radiation hardened, and had been proven on multiple prior spacecraft. You don't use too many new things on a trip to nowhere! – TFD Oct 01 '12 at 09:46
It was offered cheaper than any product from Intel or AMD when you don't need latest generation CPU's.
e.g. Xbox and PS3 didn't need the fastest CPU around, they just need a decent amount of multi-processing. They also needed a long term delivery program with the price declining to ensure long term viability and price of the consoles.
Xbox and PS3 where originally sold at a loss to start the ecosystem, and then over time they are cheaper to produce. The components don't fundamentally change but do get significantly cheaper so to ensure a healthy margin in the boxes, unlike desktop PC's which are expected to follow the latest CPU generations.
Renan
  • 5,090
  • 45
TFD
  • 258
user3624 is right when saying:
I work in civil aerospace domain and only CPUs/MCUs that made their proof are accepted, or have been use in critical systems. In particular, embedded PowerPC (e200 cores) are used in that segment. However, ARM is also playing in this field with the Cortex-R family, which is meant for real-time.
From our perspective, it is important that both PowerPC and ARM continue living since we rely on both for the safety of our systems. For example, we can embed a PowerPC on one computer that check the ARM Cortex-R computer. Since they are dissimilar, both cannot have the same bug at the same time.
Etienne
