So for the project I am working on I plan on measuring very precise changes in angle, possibly up to 5 degrees of accuracy.
  • Are polymer ink sensors (the classic Nintendo power glove flex sensor) the way to go?
  • Can they really be that accurate or are there any other alternatives to measure bend on an attached apparatus pricisely?
Electric_90
  • 2,112
Brandan B
  • 103
I think if the geometry is such that you can make the sensor flex exactly the same way for each motion, you can get 5 degree performance. If the goemetry moves around, you might not. You're likely somewhere in between these two cases. Sounds like a quick test is in order to determine if the method is worth putting more effort into.
Scott Seidman
  • 29,274
  • 44
  • 109
They can be as accurate as measuring 5 degrees (depending on the configuration) but as long as you are willing to calibrate it, that is often the difficult bit. Make sure you set it up in such a way that you can replicate it and do your own tests. You may even be able to get it better than the requirements.
ryan smith
  • 64
