i have a beaglebone card, a temperature sensor PT100 and a temperature conditionner. I'm new in beaglebone, as i see the ADC is already in beaglebone but the voltage is mx = 1.8V With my industrial temperature sensor, i connect the power supply 24Vdc, connect the PT100 then the output will be in 0 to 10V
What circuit do i need to interface the temperature conditioner with beaglebone card?
Should i use a voltage divider? if yes can someone guide to a basic diagram.
Should i use LM317 as voltage regulator?
I found this circuit in internet.
Thank you
