Problem Design a controller in the feed-forward path to minimize the effects of the two pairs of dominant poles. Use the pole-zero cancellation technique via the root locus diagram.
I have a 5\$^{th}\$ order system with two pairs of dominant poles,
Poles =
1.0e+02 *
-9.9990 + 0.0000i
-0.0004 + 0.0344i
-0.0004 - 0.0344i
-0.0002 + 0.0058i
-0.0002 - 0.0058i
Design specifications are overshoot \$<5\% \$ and settling time \$<2s\$. Using the sisotool()
function in MATLAB, the white region represents where I need my new poles to be, to obtain the desired specifications:
To compensate the system, I need to get rid, or perhaps more realistically minimize the effect, of the two complex poles. Then I need to re-shape my root locus.
This pair of dominant poles des_poles = [-2.6+2.329j; -2.6-2.329j]
, give a closed loop response to get overshoot \$<5\%\$ and settling time \$<2s\$, and can also be seen to fit in the white area above.
However, I am stuck when it comes to canceling out the complex pair of dominant poles. Should I add complex zeros, for instance,
0.0004 - 0.0344i
and0.0002 + 0.0058i
? These don't seem to yield desired results. Or should I only cancel out the poles which go unstable to the right hand side? How can I cancel out the pair of dominant poles to add the poles which bring about a closed loop within desired specifications?
Any help is appreciated.
My thought process so far (Outputs are still not making sense) I proceeded to add two pairs of complex zeros, to cancel out the complex dominant poles to end up with something like this
I then add the pair of desired complex poles, and another pair of complex poles to the left to make the compensator realizable.
