i need to connect Si7021 wich is an 3.3v I2C humidity sensor with Arduino, this sensor has open drain SCL and SDA drivers. is it possible to connect this sensor directly to Arduino 5V?.
Asked
Active
Viewed 89 times
The datasheet explicitly says that the SCL/SDA pins are not 5V-tolerant, so you'll definitely need level shifters.
Dave Tweed
- 168,369
- 17
- 228
- 393
but those pins are pulled-up to 3.3V not 5V... – moyoumos Jan 02 '19 at 07:29
Sorry, "those pins" refers to which pins exactly? Your question states that you're using a 5V Arduino. – Dave Tweed Jan 02 '19 at 12:46
the SDA and SCL pins of the sensor are pulled-up with 4.7K resistors. – moyoumos Jan 02 '19 at 18:03
