I bought a liquid filling machine -http://a.co/d/8FMFWIU. There is a centrifugal pump model Dp 521 2Amps 12Volt. I want to replace this pump with a peristaltic pump. The pump is controller by a micro controller.
The pumps that i find are rated as 12volt / 1.4Amps.
Will the difference in amps cause an issue? I am guessing the system will run slower and the new pump should only draw the current(max 1.4a) that it needs and i shouldnt run into an overheating issue. am i correct?
Codplay
No problem.
If the machine can provide 2A at 12V, then it can also supply lower currents, e.g. 1.4A. There will be no over heating issue.
Pzy
  • 357
