In a certain simulation testbench using questasim, I am trying to read the files with integers numbers which looks like,
0000
0001
0005
3864
2290
1234
0002
0004
0006
4532
3457
My aim here is to read the text file, store first few numbers in an array of integers and write that array in text output, my attempted code looks like,
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_textio.all;
use std.textio.all;
entity HFA_tb is
end HFA_tb;
architecture behave of HFA_tb is
--clock 100 MHz change to any value suitable
constant c_CLOCK_PERIOD : time:= 100 ns;
signal r_CLOCK : std_logic := '0';
--**signal r_ENABLE : std_logic := '0';
signal r_adcpulse : integer;
signal r_hitstart : integer; ---output of single threshold
signal r_hitend : integer;
signal r_hitpeak : integer;
signal r_peaktime : integer;
signal r_hitsum : integer;
signal r_opready : std_logic := '0';
--more signal
--describe HFA component here (Unit Under Test)
component HFA is
port (
adcpulse_i : in integer;
clk : in std_logic;
hitstart_o : out integer; ---output of single threshold
hitend_o : out integer;
hitpeak_o : out integer;
peaktime_o : out integer;
hitsum_o : out integer;
opready_o : out std_logic
end component HFA;
begin
--Instatiate the unit under test
UUT : HFA
port map (
clk => r_CLOCK,
adcpulse_i => r_adcpulse,
hitstart_o => r_hitstart,
hitend_o => r_hitend,
hitpeak_o => r_hitpeak,
peaktime_o => r_peaktime,
hitsum_o => r_hitsum,
opready_o => r_opready
p_CLK_GEN : process is
begin
wait for c_CLOCK_PERIOD/2;
r_CLOCK <= not r_CLOCK;
end process p_CLK_GEN;
--main testing logic for reading from text file; feed in the loop and check output
process
file in_buffer : text;
file out_buffer : text;
variable v_ILINE : line;
variable v_OLINE : line;
variable v_adcValue : integer;
variable line_counter : integer :=0;
variable block_length : integer :=0;
variable block_counter : integer :=0;
variable header_length : integer :=0;
type header is array (0 to 2) of integer;
variable H: header;
begin
file_open(in_buffer,"/home/eu18461/Data/DUNE/QuestaSim_Examples/HFA_test4_SliceTest/sample.txt",read_mode);
file_open(out_buffer,"/home/eu18461/Data/DUNE/QuestaSim_Examples/HFA_test4_SliceTest/results.txt",write_mode);
while not endfile(in_buffer) loop
if line_counter=0 then
f1 : for k in 0 to 2 loop
readline(in_buffer, v_ILINE);
read(v_ILINE, v_adcValue);
H(k) := v_adcValue;
line_counter := line_counter+1;
end loop f1;
end if;
if line_counter /= 2 and block_length /= 9 then
f2 : for k in 0 to 2 loop
r_adcpulse <= v_adcValue;
block_length := block_length+1;
end loop f2;
end if;
if block_length=9 then
f3 : for k in 0 to 2 loop
H(k) := v_adcValue;
header_length := header_length+1;
if header_length=3 then
block_length := 0;
exit;
end if;
end loop f3;
end if;
wait for c_CLOCK_PERIOD;
end loop;
if endfile(in_buffer) then
write(v_OLINE, string'("hit_start_time"));
writeline(out_buffer, v_OLINE);
write(v_OLINE, r_hitstart);
end if;
file_close(in_buffer);
file_close(out_buffer);
wait;
end process;
end behave;
Updated the code, my desired output text should look like,
Int1 int2 int3 Op1 op2 op3 Op3 ...
Int11 int12 int13 op1 op2 op3 ...
Intx inty intZ op1 op2 op3 ...
Here int1, Int2 ...etc represent the integers from the input text file, these no. goes upto a fixed block length. I want to store them, and send the remaining integers to my processing block, after the process I want the output in row format as shown in the text file and again repeat the process. Any hints will be much appreciated. Here the for loop no. indicate the integers storing length and block length after which the process i s repeated.
