I am using CubeMX and HAL to program an STM32L4. I am trying to communicate with RFM96 module using SPI, but I am getting nonsensical results.
According to the RFM96 datasheet, in order to read a byte from an address, I have to send 1 byte, MSB set to 0 (indicating read mode), the other 7 bits indicate the address. In the screenshot below you will see I am attempting to read the value of register 0x03, which is supposed to return value 0x0B (default). The problem is that instead of receiving only 0x0B, I receive what looks like ALL the register values of RFM95. You will see that 0x0B is present too.
I have let the clock go on for 8 bytes more than I need to, just to demonstrate the issue. Furthermore, I only experience this result if the LSB of the first byte is 1. If I request the data at address 0x02, I would get zero response (picture below). I get the same response if I send 0x00.
This is the code I use to generate the above logic analyser samples.
uint8_t data[10];
data[0] = 0b00000011;//sent first
data[1] = 0b00000000;
data[2] = 0b00000000;
data[3] = 0b00000000;
data[4] = 0b00000000;
data[5] = 0b00000000;
data[6] = 0b00000000;
data[7] = 0b00000000;
data[8] = 0b00000000;
data[9] = 0b00000000;
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_RESET);
HAL_SPI_Receive(&hspi1, (uint8_t *)data, 10, 100);
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_SET);
This is my SPI init function:
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 7;
hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
This code is rudimentary; I am using a logic analyser to debug. Can anyone spot what I am doing wrong? As far as I can tell, I am giving the RFM95 all the requirements it needs in terms of MOSI, SCK, and NSS.
