As shown in the image below, the USB port's metal enclosure is touching the copper clad of the PCB (which is a ground plane).
Can Bad Things Happen™ if the port's enclosure is grounded?
I beep-tested the 4 pins with the enclosure, and none of them are connected to it. However, could some shorts be made when plugging something into the port?
Fine Man
  • 191
Assuming that there are not more than one GND then yes it is recommended to Ground the USB port enclosure.
For more information please look at this thread. USB Shield. To ground or not to ground?
m-walker95
  • 255
