How much resistance does the package of an IC contribute to the paraistic resitance of a circuit? (most applicable to mosfets)
Voltage Spike
  • 75,799
  • 80
  • 208
  • Does it even matter? I mean, wouldn't the output impedance of the circuit itself be significantly larger than the bond wire/pin resistance? – Linkyyy Nov 29 '18 at 22:21
  • If your designing power circuits, mΩ's can matter nowadays, with many new power mosfets having rdsons in the mΩ range. If your selecting components, you know if you get a the same die in a D2 instead of a MLP package you'll get lower resistance. – Voltage Spike Nov 29 '18 at 23:22
  • That is not something that the manufacturer take into account when they specify rds in the datasheet? – Linkyyy Nov 30 '18 at 07:35
    Actually, I'm not sure on that one, probably. Either way, if your buying the same part number the package makes a difference – Voltage Spike Nov 30 '18 at 19:01
It's below 2.5mΩ at DC on most packages
Understanding the Effect of Power MOSFET Package Parasitics on VRM Circuit Efficiency at Frequencies above 1MHz
Voltage Spike
  • 75,799
  • 80
  • 208
