I need to connect seventh port (SGMII) of KSZ9477S switch to AFBR5803AQZ optical transceiver (It's 100 Mbps). I wanted to use PHY with SGMII interface and fiber mode (VSC8658XHJ), but it's too expensive. I also found 88e1111 Marvell IC which should be able to convert SGMII to fiber interface, but it seems that it converts only to 1000BASE-FX while I need 100BASE-FX. Can somebody give me a clue how can I connect SGMII port of KSZ9477S switch IC to AFBR5803AQZ optical transceiver using cheaper solution?
Asked
Active
Viewed 457 times
If the IC converts 1000 Base FX, it should also convert 100 Base FX, look for register settings in datasheet. Please add datasheet link, I will try to look as well. – AKR Nov 26 '18 at 15:11
Thank you for the response!) Here is the link to the datasheet [link](http://www.cexiinc.com/cexilib/CEXI_CAD_Footprint_Data/PDF's/Desc/MV-S100649-00H_88E1111_Datasheet.pdf) – Andy Nov 27 '18 at 05:17
Please correct me if I am wrong, there is not anything called as 1000BASE-FX and even Marvell IC doesn't show anything for 100BASE-FX. Sorry for late response. – AKR Dec 04 '18 at 14:47
The 88E1111 Product Brief says right on the cover "Integrated 10/100/1000 Ultra Gigabit Ethernet Transceiver". What more do you need?
Dave Tweed
- 168,369
- 17
- 228
- 393
Thank you for reply. Yes, indeed it says so. But according to the datasheet it seems that this IC can only convert from SGMII to 1000BASE-LX and 10/100/1000 numbers refer to copper mode (10BASE-TX/100BASE-TX/1000BASE-TX). Here is the link to the datasheet [link](http://www.cexiinc.com/cexilib/CEXI_CAD_Footprint_Data/PDF's/Desc/MV-S100649-00H_88E1111_Datasheet.pdf) – Andy Nov 27 '18 at 05:46
