I have 2 different powerbanks, both have 10000 mAh and both are rated for 5V 2A power input.
I have noticed that they draw a different amount of current despite using the exact same charger (5V 3A), same port and the exact same USB-B-Micro cable.
One of them draws 1.6A while the other one draws only 0.7A. Same results on further retries.
How can there be such a difference?
Is the flawed latter charging IC (0.7A) too paranoid of overdrawing current?
Edit 1:
- The slower powerbank that charges at 0.7A is newer and has been used much lesser than the faster powerbank so far.
- Both powerbanks only charge faster when compromising cable length. The limit in each case is 2A as the specification said, which can only be reached on slower powerbank when using a cable shorter than 10cm/4 inches. However, one of the powerbanks charges significantly slower with the same cable length, in fact the exact same cable. 0.7A with the exact same cable as the faster powerbank at 1.6A.
Edit 2:
- Both of the powerbanks were at around 25% of charging state during the test. This means that their internal terminal voltage of the Lithium-Ion cells is rather low but very similar.
- According to imprint, both powerbanks use Lithium Ion, not Lithium Polymer.
- Again: Both are tested using the exact same cable.
