Looking at the linker script for my part (ATMEGA168PD), the data
region has an origin defined as starting at 0x800060
MEMORY
text (rx) : ORIGIN = 0, LENGTH = __TEXT_REGION_LENGTH__
data (rw!x) : ORIGIN = 0x800060, LENGTH = __DATA_REGION_LENGTH__
eeprom (rw!x) : ORIGIN = 0x810000, LENGTH = __EEPROM_REGION_LENGTH__
fuse (rw!x) : ORIGIN = 0x820000, LENGTH = __FUSE_REGION_LENGTH__
lock (rw!x) : ORIGIN = 0x830000, LENGTH = __LOCK_REGION_LENGTH__
signature (rw!x) : ORIGIN = 0x840000, LENGTH = __SIGNATURE_REGION_LENGTH__
user_signatures (rw!x) : ORIGIN = 0x850000, LENGTH = __USER_SIGNATURE_REGION_LENGTH__
The .data
output section does not explicitly define an address, but instead only refers to the data
region ...
.data :
PROVIDE (__data_start = .) ;
*(.data)
*(.data*)
*(.gnu.linkonce.d*)
*(.rodata) /* We need to include .rodata here if gcc is used */
*(.rodata*) /* with -fdata-sections. */
*(.gnu.linkonce.r*)
. = ALIGN(2);
_edata = . ;
PROVIDE (__data_end = .) ;
} > data AT> text
...yet the .data
output section ends up at the address 0x800100
rather than 0x800060
00800100 l d .data 00000000 .data
This turns out to be the correct address for the start of the .data
segment on this part because 0x800060-0x8000ff
is reserved for some registers and is not general purpose RAM.
There is no origin in the linker script that would specify the 0x800100
address and there are no command line parameters to the linker that would tell it this magic, part specific number. There are no other output sections in the data
region that could be pushing the .data
output section higher in memory to the 0x800100
location (.bss
and .noinit
both follow .data
and are relative to it).
I've also noticed that if I rename the .data
out section to anything else, its origin lands at the beginning of the data
region at 0x800060
as expected. Somehow the linker knows that an output section specifically named .data
must start specifically origin 0x800100
rather than the start of the region specified in the linker script.
It is as if somewhere there is a .data = 0x800100;
or -Tdata=0x80010
, but I can not find it anywhere!
My question is: How does the linker know to start the .data
addresses at 0x800100
for this part?
