here's what I see, we have a op-amp in the middle with a simple 22k feedback and 10pF to stop oscillations.
then we have the input signal going to the non-inverting input through a 22k resistor.
between these two nodes is a potentiometer with the center tab to a gyrator. a gyrator acts like an inductor with one end grounded, it absorbs low frequency currents.
Now if you turn the potentiometer one way and the gyrator soaks up the input signal and sees less of the feedback signal - so the low frequencies are "killed" both by the gyrator sucking in the input signal and by the gyrator not attenuating the feedback signal.
If you turn it the other way the gyrator is close to the feedback signal and distant from the input signal, so it soaks up the low frequencies in the feedback signal, but not from the input signal allowing a larger amplitude to be produced.
C008 R012 form a high pass filter stopping low frequencies from going into the gyrator, causing the base control to roll off below 300Hz.
