Can anyone please help with the following. I am in the process of connecting a Schneider Electric Servo Drive for a Cnc project.
I want to wire a fault output from one of the 5 drive outputs. (Do1-Do5).
The manual says" Use an appropriate external protective circuit or device to reduce the risk of inductive direct current load damage. "
The output will simply be disconnecting the enable to the drive if a fault is detected within the drive. I am not switching any other load.
The question is do I need to protect this circuit as described in the manual or can I wire directly?
I have attached a screenshot of the circuit from the manual.
