I understand the high-level function of OTAs, that they provide an output current proportional to an input voltage. But what I don't understand, and what I can't seem to find any information on online, is exactly how they're used and what the function of the different connections is.
The most pressing questions I have are thus:
- What is the function of \$I_{bias}\$? Why are there diodes between this pin and the two inputs? I've seen them called linearizing diodes; how do they linearize the response of the circuit?
- What is the function of \$I_{abc}\$? As I understand it, it provides a scaling factor; is this correct? How does it do so?
- What is the (exact or approximate) formula for \$I_{out}\$ as a function of \$V_{in+}\$, \$V_{in-}\$, \$I_{bias}\$, and \$I_{abc}\$?
- What are the standard application topologies for an OTA? Op amps have the standard inverting and non-inverting amplifier topologies, and slightly more complicated summing amplifier and difference amplifier, integrator and differentiator, but are there any common circuit idioms for the OTA?
- Internally, how does an OTA work? (this is perhaps best left to a separate question, though.)
