I've seen power protection that uses:
  • MOV (metal-oxide varistor)
  • Inductor
  • TVS diode
Application Note: Transient Voltage Suppressors (TVS Diode)
Applications Overview
Combined MOV Varistor and TVS Diode Protection Scenarios
I didn't see any design guide for the inductor selection, so I choose 1 A inductor 4.7 µH. But doesn't that mean it will carry the surge current that TVS should clamp?
Input protection circuit in implementation Inductor NR series S type ratings
I'm not sure if 4.7 µH the right selection or not.
Tim Williams
  • 22,874
  • 71
Hasan alattar
  • 487
  • I do not see any reason for placing an inductor between the protective elements. If used, it should be placed after the TVS diode so that the diode can do it’s job. – Stefan Wyss Oct 08 '18 at 19:30
  • the first picture is not mine, as much as i understand, the inductor is there to delay surge current from TVS diode so the varistor takes most of the power of that surge. i dont know if its effective or not that what comes in my mind – Hasan alattar Oct 09 '18 at 05:53
  • Why don’t you simulate it? – winny Oct 09 '18 at 06:11
  • i've never used simulation, only the one altium provide for very simple circuits RC, LC, filters that already have spice model by default. – Hasan alattar Oct 09 '18 at 06:52
  • i did use LT spice today, it just doesnt give what i should do, good to see that 8kV voltage gets shunted by the varistor and zener diode but it need much more study of spice simulation i guess to simulate the real component and i guess current and voltage should be measured – Hasan alattar Oct 09 '18 at 08:54
Inductance value will be depends on the surge rise time and TVS clamping time. Current rating will depend on the MOV breakdown time and the energy of the targeted surge.
  • As well as for nominal load, and the surge waveform: is this for IEC 61000-4-5 and if so then what level; or say, automotive load dump? The latter is likely to fuse a few-ampere inductor! – Tim Williams Jun 09 '22 at 15:20
