I am developing a VOIP application. Most clients use a wired Ethernet connection, but some of the clients need to have a wireless connection. Currently the core board is using:
  • Cortex-A8 (TI AM3359)
  • 256MB RAM
  • 2GB Flash
  • WiFi 802.11N
But the range of WiFi is very terrible, compared to ~5Km walkie talkie, I know XBee might work but I have never used it in either production or development. My requirements for the digital wireless communication are:
  1. 1-5Km in Range (1Km with minor obstacles or 5Km line of sight)
  2. 100Kbps (12.5KB/s) lowest transfer rate condition.
  3. multiple clients (100 clients)
  4. relatively low price.
  5. preferably: support TCP/IP, support simple encryption (so no need to modify software stack much)
So should I use XBee? or any other alternatives? Thanks.
boardbite
  • 4,892
  • 47
  • 73
c2h2
  • 415
Xbee modules are an option, as are other 800 to 900 Mhz RF modules, but subject to some constraints.
I suggest you make your choice by looking at Digi's comparison matrix table of the different Xbee options; there are at least three that suit your application, and they are point-to-multipoint capable.
The table states you can get outdoor range up to 40 km (for example, with the XBee-PRO 868), but note a couple of things:
  • this is outdoors range; if the same transmission were attempted in an indoors environment (or generally a situation where there are intererence sources within the Fresnel zone), your range will drop markedly.
  • this requires using a high-gain antenna, so that may be a constraint depending on what your device construction allows (in fact, I think most of the distances specified in that table are with a dipole antenna).
  • some of the model variants are only available selectively in Europe or North America, if this matters.
  • for some insight on performance metrics, it's worth reading this app note, where they demonstrate nearly 0% packet loss at distances up to 40 km range, but with specific conditions.
Note that the data rate for the long-range models might not meet your requirement of 100 Kbps, which is a tough ask although...
Alternately, GSM modules perform your bandwidth requirement easily in a different context, which brings up an alternate idea: You can also consider instead using GSM modules for your communication, although this obviously might turn pricey since you state there are on the order of a 100 users.
One final suggestion is to use the low- or medium-range Xbee models, but use extenders/repeaters/relay-units to cover the required distance (or in case of the Zigbee variant of Xbee, you can even use the units in the mesh as extenders themselves). Setting up a robust Zigbee network takes some development effort, but this is somewhat simplified with the firmware stack on the Xbee ZB units.
boardbite
  • 4,892
  • 47
  • 73
