Low Impedance Guitar Pickup
I am terribly confused ... I tried myself at building a low impedance guitar pickup some time ago.
Quick LowZ Pickup Intro
Basically just two loops of aluminium with two magnets, a humbucking guitar pickup with a single loop per magnet.
The three tongues are the terminals, but the outer ones are connected so that there is only one output plus ground. The magnets poles are on the top and bottom, one of them is rotated 180 degrees. This results in the desired humbucking effect.
The Plan
I hooked up the whole shebang to my audio interface (connected to the Gnd and Hot Pins of an XLR with the Cold shorted to ground) and lo and behold there actually is audio coming from this thing.
Problem is that the output is super quiet and I have to crank the gain to +30db before I can hear something. My plan was to design a simple opamp preamplifier to boost the signal as close to the source as possible.
Now I definitely am no electrical engineer, but this is not my first rodeo. So I looked up the basic inverting opamp circuit and hooked it up on a breadboard. More specifically I used the schematics from here, but modified it to give me about 35x gain (about +30db). Hooked the output up like before, signal to hot, gnd to gnd and cold. This is a TL072 for testing, I meant to switch that out for a ultra low noise opamp once this is working.
Opamp on Breadboard
(If I remember correctly this is Figure 4 from the Nuts'n'Volts article, just to give you an impression of my breadboarding conditions, I just noticed that it doesn't even show the output connection)
The Problem
Hum! Instead of sweet guitar sounds I get hum. Definitely no signal in there.
What I Tried
For testing purposes I hooked up a poti to control the gain and found that the hum disappears at unity gain. The signal is audible again then.
Did a two stage design with a unity gain and a 35x gain stage. Still humming, no signal.
Checked the unity gain bandwidth thingy, but at 3 MHz for the TL072 35x gain shouldn't be a problem.
Tried a 1:35 transformer instead... But transformers are magic to me and I didn't manage to get anything from it.
The Question
I suspect that it's the super low impedance of the pickup itself. Basically it's a short against ground. But this is where my electrical knowledge fails me.
TL;DR: What am I missing in designing my LowZ guitar pickup preamp?
Dave Tweed
  • 168,369
  • 228
  • 393
fho
  • 151
    long leads on the breadboard will pick up noise – jsotola Sep 21 '18 at 15:05
    Maybe my head is on sideways this morning, but in the photo above, the pinout for the TL072 looks wrong on the breadboard. Like maybe you misplaced where you think pin 1 is.... also, power connections? – Chris Knudsen Sep 21 '18 at 15:11
  • @ChrisKnudsen Pin 1 should be in the upper left in the picture, the pins being 1OUT, 1IN-, 1IN+, Vcc-; 2IN+, 2IN-, 2OUT, Vcc+ as per the datasheet. Power connectins -> fair enough ... I should probably take down the picture ... I took it some time during buildup or after teardown apparently. – fho Sep 21 '18 at 15:14
  • @jsotola Agreed, but it's more the "put your finger on the signal line" kind of hum. Deep and buzzing. Ground hum. – fho Sep 21 '18 at 15:16
  • @fho - Indeed (my head is on sideways). I was thinking of the 071 pinout. I better find more coffee. – Chris Knudsen Sep 21 '18 at 15:18
    Interesting design. My suggestion would be to look for preamp circuits designed specifically for ribbon microphones, which have a similar extremely low source impedance. You basically want to think of the pickup as a current source, not a voltage source, so "transimpedance amplifier" might be a useful search term. – Dave Tweed Sep 21 '18 at 15:58
  • Just in case it will change the (perceived) bad reception of this question: The pickup straight into a mixer produces an almost usable signal. But my mixer is kind of old and I was hoping that I might get a better result with a dedicated preamp with a more current op amp. But so far I failed to get any usable results from my TL072s ... To be fair I was completely unaware of the +-11V supply minimum. I think I saw other designs online that used the TL07xs of a 9V battery. *shrugs* – fho Sep 23 '18 at 16:30
  • @fho - What +/- 11 V minimum? Page 10 of the TI data sheet says a difference of 10 volts (+/- 5) will work, so a 9 volt will do. Problem is, you'll need to construct a virtual ground if you use a single battery. And please, for the love of pity, get rid of the picture and replace it with a picture of what you're actually using. – WhatRoughBeast Dec 19 '18 at 21:10
  • @DaveTweed Ribbon mic or a moving coil gram amp (They are pretty similar). If doing the opamp thing you want a bipolar device designed for low source impedance (the voltage noise of a 07x will kill you for this), but really a whole pile of low Rb' transistors in parallel is the way to bet. – Dan Mills Feb 11 '22 at 12:00
Apart from the TL074 requiring a minimum power supply of 10 volts to guarantee working correctly you are facing a big up-hill struggle with this idea. I wouldn't use a site that recommends running this chip (or the TL064) from a 9 volt battery.
Consider that a proper humbucker has maybe 1000 turns on each pup and this means that for a certain string vibration you'll get 1000 times the signal compared to a single turn.
Then, because the basic output signal is so low, you are "fighting" hum and noise from other sources (such as the basic wiring from your masterpiece to the pots and the jack socket). This hum/noise cannot be countered by the hum-bucking principle.
Added to this, you might use an op-amp with a moderate noise performance to keep hiss at bay for a normal humbucker but, for your masterpiece you'll need a noise performance that might be 1000 times better. A typical reasonable audio op-amp has a noise spectral density equivalent of about 10 nV per \$\sqrt{Hz}\$ but money won't buy one that is 1000 times better.
Forget this crazy idea and wind more turns and get more signal.
    I should add that this is by no means "my crazy idea". The basic design is sold by companies like Lace (Alumitones: https://goo.gl/images/ZdpBhn). They don't split the tongues in three, and basically use a current clamp on the shared part. Also there exist several old posts in DIY audio forums where people build this kind of pickup. – fho Sep 21 '18 at 19:44
    Also: my plan was to put the opamp on a little pcb on the inside of the pickup, as close as possible to the source. Smd parts with the backside of the pcb being copper contacts to the tongues. – fho Sep 21 '18 at 20:00
    It is your crazy idea unless you can demonstrate that it is the same as a marketed product/design. The devil is in the detail; I have read all your design details and if someone else proposed the same and told me they could sell hundreds a year to proven satisfied customers then I would suggest that someone is deluded. As I don’t have detailed design info on those that are currently available on the market nor any idea about customer opinion, I can’t comment other than to reiterate that your basic idea is flawed and crazy in the face of my answer. – Andy aka Sep 21 '18 at 20:03
    No matter how close you place your opamp you can’t override its basic flaws in that it will produce too much background noise/hiss to be anything more than a curiosity. I’ve built pups by the way! – Andy aka Sep 21 '18 at 20:05
    Andy is correct, your signal is buried in noise with this approach. You might try a transimpedance amplifier circuit to have a hope of any success. Start with a gain somewhere around 1000 - 10,000. – evildemonic Sep 21 '18 at 21:02
    And Lace selling a similar product (using a transformer for "amplification") does not count for you? Not to discredit your answer, I am definitely not the expert here. – fho Sep 21 '18 at 21:04
    OK... I'll try my luck with a tranceimpedance amplifier. – fho Sep 21 '18 at 21:34
  • @fho, you are absolutely right, regardless of the unnecessarily histrionic answer from "Andy aka.' Your pickup is very similar to the "Lace Alumitone" pickup that has recently become popular, which is basically a "one-turn pickup." What I don't see in your circuit, which the alumitones have, is a step-up transformer to increase the voltage. There was a video released recently about this pickup design, which may be interesting to you - https://www.youtube.com/watch?v=5qMdDuUzgig. Note that Dylan references the patent, so you may want to look at that to get the transformer specification. – Mike Battaglia Oct 24 '20 at 02:21
  • @MikeBattaglia my answer is not histrionic and, if the idea behind the question was good, or useful, maybe the media has forgotten to report this fact? – Andy aka Oct 24 '20 at 08:37
  • Varying the turns changes the voltage/current ratio but not the *power*. More turns gives higher voltage *but lower current*. Typical audio gear is voltage-sensing so more voltage usually translates into "louder". But there are trade-offs. More turns means higher self-capacitance, which gives them their distinctive midrange resonance, but less treble. It's perfectly valid to build a 1-turn coil pickup - you just need to feed that into current-sensing gear... which you'll probably have to make yourself. – Alex Shroyer Nov 13 '20 at 03:10
engineer's answer
The easiest, fastest, and cheapest solution to this problem is to copy what Lace did with its Alumitone series:
  1. short the "tongues" together
  2. magnetically couple a current transformer around the middle "tongue"
The current transformer boosts output voltage and output impedance, both of which make this pickup work better with existing audio gear.
mad scientist's answer
You can proceed without the current transformer, but with much more effort.
You know magnetized strings induce a current in your coil. However, you've broken your coil by leaving gaps between the 3 "tongues" of metal. It worked with the XLR input because these are often DC coupled and low-z (by audio standards), so the impedance mismatch was tolerable.
There are 2 issues with the "broken coil" to solve:
  1. need to close the loop with a (low-z input) circuit
  2. you should ground the center tongue and use duplicate circuits for both outer tongues, if humbucking/common mode noise rejection is important to you
Amplifier suggestions:
With a traditional op-amp, you might be able to get away with something like a photodiode amplifier circuit. You may even be able to adapt the typical inverting op-amp circuit (Fig. 3 from the linked nutsvolts article), but make Rin 0.1Ω, and Rfeedback 5Ω or 10Ω to start. The other values in the circuit can remain unchanged. Definitely this should be DC coupled because otherwise the capacitor will be enormous - And it's probably best to use 2 9V batteries in a bipolar supply with true earth ground in the center, for headroom and op-amp stability reasons.
However, it may be worth exploring "current-sensing" op-amps like the LM3900 or LM13600, as their example circuits are often built with low-z sources in mind.
summary
I really like these low-z pickup designs, but low-z pickups don't have a wealth of existing designs, DIY guides, and general "lore" like high-z pickups have. You need enough background to know which values to change and how much they should be changed. So don't be afraid of digging in to how transformers work. You can skim (or skip!) the calculus, but get a feel for things like: impedance, inductance, magnetic coupling, where the field lines flow, and Ohm's law.
Alex Shroyer
  • 1,310
