The wide prong is neutral on 15 amp US power outlets.
Is there a reason it was designed this way, or could the narrow slot just as easily have been neutral instead? Was this design decision arbitrary?
I think the logic is that it's more important that the neutral wire of some appliance never be connected to hot, than it is for the hot wire not to be connected to neutral.
I don't know a definitive historical answer. From an electrical perspective there's no reason to prefer one over the other, at least once the connection is made.
There are two potential reasons I can think of:
1) If the plug is only partially inserted (or has been slowly falling out), the wider prong may be more likely to make contact. If only one of the two is connected, it's safer for it to be the neutral one.
2) If a child happens to pick up a paperclip or some other bit of metal and decides to stick it in the plug, there's a chance it will only fit in the larger of the two slots, or maybe psychologically they would tend to choose the larger of the two slots. Don't rely on this!
I am a Mechanical engineer but I have extensive knowledge of electrical engineering, I don't think it has anything do of current flow from hot wire to neutral wire, so why initially they decided to make the neutral slut wider is like other friends said, the wider slot can accept foreign objects better and easier than the narrower slot so possibility of electric shock is more if they make the hot slot wider. So they decided to make the neutral slot wider.
