I am currently trying to build a package for a through-hole potentiometer in Eagle Cad and I want to incorporate holes in my PCB for the metal tabs on the side of the pot.
I determined that these holes should be at least 1.8 mm in diameter. However, the moment I select a diameter greater than 1.0 mm I get this weird forward slash through my drill hole icon and I'm not sure if this is okay or what it means (see figure below).
Here is the potentiometer's datasheet. I am using PTV09A-4 (Horizontal/Rear Mount, Bushingless)
ocrdu
  • 8,705
  • 30
  • 42
You haven't mentioned which version of Eagle you are using, but I had a quick play with Eagle 9.0.1. Changing from 0.8 mm to 1.8 mm in 0.1 mm steps produced a range of centre definitions (bow ties, Ys, stars) until it reached the final slash. It doesn't mean anything in particular, as far as I know (many boards made), so don't worry about it. Double check your Gerbers if you are worried :)
awjlogan
  • 7,879
  • 45
Eagle shows different drill sizes with different symbols to group them, so you can easily see, that they differ in diameter. This is probably why!
Ole
That is the reason, that Eagle uses different symbols for different drills. This one happened to be a circle with a slash, coincidentally ASCII 0xD8 and a letter in a few languages.
AlStu
  • 81
