When using the HAL (Hardware Abstraction Library) for any of the STM32 micro controllers:
For a given peripheral, why do you have to call an HAL_...init() , as well as a HAL..._MspInit() - why are several 'inits' separated?
m00wn
  • 342
The ST User Manual UM1725 - Description of STM32F4 HAL and LL drivers, see pages 61 - 63, gives an explanation:
The peripheral initialization is done through HAL_PPP_Init() while
the hardware resources initialization used by a peripheral (PPP) is performed during this initialization by calling MSP callback function HAL_PPP_MspInit().
The MspInit callback performs the low-level initialization related to the different additional hardware resources: RCC, GPIO, NVIC and DMA.
(MSP: MCU Support Package)
and
2.12.2 HAL global initialization:
HAL_Init(): this function must be called at application startup to
- initialize data/instruction cache and pre-fetch queue
- set SysTick timer to generate an interrupt each 1ms (based on HSI clock) with the lowest priority
- set priority grouping to 4 preemption bits
- call HAL_MspInit() user callback function to perform system level initializations (Clock, GPIOs, DMA, interrupts). HAL_MspInit() is defined as “weak” empty function in the HAL drivers.
m00wn
  • 342
